Quantcast
Author Topic: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio  (Read 9905 times)
Offline imwastefull
Re: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio
« Reply #90 on: Dec 17, 2018, 14:21:06 »
Gah, I don't think the xs750 MC will work. The price is right but it mounts completely differently.
Offline doc_rot
« Reply #91 on: Dec 17, 2018, 16:54:52 »
they have other bore diameters / outlet styles available as well. reservoir is sold separately
https://store.bevelheaven.com/Brake-Related-Parts/Master-Cylinder-Brembo-Rear-Brake-11mm-Black-Straight-Outlet/
Offline teazer
« Reply #92 on: Dec 17, 2018, 18:26:46 »
I have a Chinese one with oval slots that allow for 40=5-50mm center to center.  GSXR I have are 50mm and so is an early R6.
Lockheed made a race rear caliper with 55mm spacing but those are really expensive - if you can find one.  I have a new one here somewhere that came with some race bike resto that I did. I have it put aside to replace one on a TZ.
Try RD400 or XS and see what size they are.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #93 on: Dec 18, 2018, 06:42:19 »
You may want to ask for bolthole-spacing, just to be sure, that you guys in the US haven't got a different spacing or something like that.
My Blog:
Offline imwastefull
« Reply #94 on: Jan 02, 2019, 08:45:03 »
Now that the holidays are over and spent, I stole a few hours to work on the race bike. A generous fellow on the sr500 Facebook page shipped me a used rear master and I also had new front brake lines and a grip full of crush washers show up in the mail so I decided to give the brakes a go.
And then I pulled my hair out all evening. No matter what I did, I couldn't get the front brakes to bleed. Even after an hour of pumping away at the mity-vac, these brakes won't bleed. As near as I can tell, the front master is fine and not leaking and it gives plenty of power. All the crush washers are new and nothing is leaking so I can tell.
I'm at a loss. I'm just going to have to keep tinkering.
Offline pidjones
« Reply #95 on: Jan 02, 2019, 08:50:56 »
You might need to prime the master a few times. I've had to hold my finger over the outlet and pump until it flows fluid well, then connect it and bleed air out of the joint.
Offline imwastefull
« Reply #96 on: Jan 02, 2019, 08:54:57 »
Pics
Offline imwastefull
« Reply #97 on: Jan 02, 2019, 09:03:04 »
Now that you say that, it reminds me of something. I tried to prime the master and I got excellent pressure at the line, but it wasn't sucking in any fluid. Later, I had this air bubble just before the master and no matter how many times I pumped it, the bubble wouldn't move. Maybe my inlet is clogged? However, I was able to get fluid into the calipers with a mity-vac.
Offline NoRiders
« Reply #98 on: Jan 02, 2019, 09:17:10 »
I had this issue on my Honda after cleaning out a clogged with old fluid m/c. I tried everything, even a syringe from the calipers backwards...nothing would give me a bleed even though the m/c felt fine. There was a minute hole in the reservoir chamber/piston tract that allows fluid into the piston chamber, cleaned it out but still nothing!! I fitted a repro m/c from a trusted supplier and bingo first time bleed and all is well.
Still not too sure wtf was up with the original m/c?
Offline imwastefull
« Reply #99 on: Jan 02, 2019, 09:40:40 »
I should just buy a rebuild kit or a new mc but I'm not sure what mine is. Stock gsxr? Anyone know what master this is?
