Author Topic: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio  (Read 9500 times)
Offline imwastefull
Re: SR500 RACE BIKE - Tracy body kit - Survivor - Ohio
« Reply #120 on: Jan 23, 2019, 14:26:03 »
I appreciate it, brother! feel free to drop me a line!
Offline imwastefull
« Reply #121 on: May 10, 2019, 20:40:22 »
Yo! Just wanted to give you guys a quick update:
I got the forks rebuilt and polished up, new neck bearings, new tires, new exhaust gasket, brakes sorted and working well. This dirty bird was ready to finally go on her maiden voyage!
Kicked her over, got her putting along, pulled the clutch in and clicked into first gear and WHAM!
the clutch is stuck. 😑
At any rate, as soon as I get the brakes sorted on my chopper, I'll be getting back into this bike because I can't wait to ride it.
Online canyoncarver
  • 'hacking is learning'
« Reply #122 on: May 12, 2019, 23:24:33 »
That is really cool.
Offline imwastefull
« Reply #123 on: Jun 11, 2019, 22:36:38 »
Is it normal when your clutch comes out as one glued together lump?
Offline sandmanred
« Reply #124 on: Jun 12, 2019, 07:37:27 »
I had one apart recently.  Hard to tell from the pics but it looks like it might be  fiber (not cork) friction pads.  My 78 XS400 came with a clutch with fiber pads.  I just got it last fall.  From what I can tell the bike sat for about 6 years before I got it.  The clutch cable was loose when I got it so the PO thought the cable was broke.  The pads in the clutch rusted and stuck the steel plates and about 1/3 of them delaminated and from the friction plates and got everywhere in the engine case.  The loose pieces stacked up in the clutch and caused the cable to go way out of adjustment. It took a while to figure out but in the end I replace the friction plates (cork pads) and re-used the steel plates after scrubbing off the rust with 600 sandpaper and it works fine now.
Good luck with yours!
Offline brad black
« Reply #125 on: Jun 12, 2019, 09:49:21 »
Offline imwastefull
« Reply #126 on: Jun 12, 2019, 10:16:43 »
Yeah, I do think that this is fiber friction pads. I was able to break them loose and clean up the steels and I think it's going to be ok. It's a bummer that the oil filter cap broke. 😒
Offline Brodie
  • Gold Coast, Queensland
« Reply #127 on: Jun 12, 2019, 10:47:24 »
If I remember right that particular bolt is know for being over torqued and stripping out the case. So I would say a broken bolt and cover is a better option.
Offline imwastefull
« Reply #128 on: Jun 12, 2019, 11:05:35 »
@brodie - I totally agree. I'd much rather spend $30 on a new cover than chase threads in the case 🤦
Plus, I got a chance to snag a Peace sign Motolanna cover that'll make this bike even uglier 🙌
Offline imwastefull
« Reply #129 on: Jun 12, 2019, 21:11:58 »
Why didn't anyone tell me that an sr500 clutch cover doubles as a waffle iron?
