Author Topic: Same size and width wheel and tire front and rear?  (Read 543 times)
Offline fuego
« on: Dec 06, 2018, 13:52:30 »
I need some help here: I am working on a Nighthawk 250. It has 18" front rim and 16" rear rim. Tires are f:90/100-18, r:120/90-16.
My goal is to replace rear rim to 18". Look less like chopper, more like cb350ish cafe. Easiest method is to find another front rim off the same bike and lace the rim to existing hub. This actually measures out and works! Before I do anything stupid I need some advice from the experts here.
1. Is this safe?
2. Can I have the same tire on the front as well as the back? (just from experience every motorcycle rear tire tends to be wider in general)
3. What about performance?
4. How can i expect the bike to handle after the mod?
1978 Honda CB125s
2000 Honda Nighthawk 250
Offline irk miller
Re: Same size and width wheel and tire front and rear?
« Reply #1 on: Dec 06, 2018, 14:45:35 »
You need a tire that can be used for front and back applications.  They will be listed as such.  It will change your geometry a bit going from 16 to 18, but especially if you run a tire in the rear that is taller than the front.
Offline focusinprogress
  • City Limit Moto:Parts-Service-Apparel (716)8038606
    • City Limit Moto
« Reply #2 on: Dec 06, 2018, 15:47:36 »
your factory tire sizes are showing a 2.5% smaller circumference rear tire that's also 20% wider than the front. stick with those percentages give or take to make the least amount of change to overall geometry. the trouble is to get that you're looking at a 120/70/18 rear tire which typically is a front tire size, there's a few that make this size as a rear or as an "either"......but might open up some serious options if you get into a 19" front wheel 18" rear.....then you're into super common sizes f/r like 100/90-19 front 120/90/18 rear.
For all your gear needs, check out CityLimitMoto.com
DTT10 code for 10% off at checkout
Offline killerx
« Reply #3 on: Dec 06, 2018, 16:04:24 »
If all you can find is a front tire in the size you want for the rear, you can flip the tire so it is rotating against the arrow.
05 Victory Hammer(110hp 115tq @ the wheel)
73 Honda Cl350(Haven't decided what to do with it) SOLD
75 Suzuki GT380
Too much of everything is just enough.
Offline Tim
  • Administrator
    • DO THE TON
« Reply #4 on: Dec 06, 2018, 17:27:36 »
Is the diameter of the rear hub about the same as the front?  Same width for the spoke mount flanges?  The angles of the spoke holes in the rim are specific to the diameter and width of the hub.
Buchanan Spokes can get you a set of nice spokes to make it work, if the hub is close to the same as the front hub.  Or, you can get a different rim for the rear.  How many spokes?
Avon RoadRider tires come in 18" universal size for front/rear use.  I had them on my XS650 cafe racer which had 18" rims on both wheels.
"Quality . . . you know what it is, yet you don't know what it is. But that's self-contradictory. But some things are better than others, that is, they have more quality. But when you try to say what the quality is, apart from the things that have it, it all goes poof! There's nothing to talk about. But if you can't say what Quality is, how do you know what it is, or how do you know that it even exists? If no one knows what it is, then for all practical purposes it doesn't exist at all. But for all practical purposes it really does exist."
Offline zrxxx
« Reply #5 on: Dec 09, 2018, 00:02:59 »
+1 on the avon roadriders; great tires. Will the taller rear tire clear the swingarm?
Sent from my SM-G965U using Tapatalk
Offline fuego
« Reply #6 on: Dec 10, 2018, 16:25:37 »
yes + wanted to get shock to without it looking hedious.
I am planning for avon roadriders :D
1978 Honda CB125s
Offline fuego
« Reply #7 on: Dec 10, 2018, 16:26:48 »
it is the same. rims need 36 holes but worried about the angles of the spoke hols on the rims being at an incorrect place.
1978 Honda CB125s
