Author Topic: Lil Smokey. 1975 Yamaha RS-100 Build  (Read 1903 times)
Offline pitobread
Re: Lil Smokey. 1975 Yamaha RS-100 Build
« Reply #30 on: Jan 12, 2019, 21:22:36 »
It was nice today.  Ripped this around the yard.  Didn't get it up on the pipe yet but it is fun.  May try and get a rip on it tomorrow.
Offline stroker crazy
  • crazy as a fox
« Reply #31 on: Jan 12, 2019, 21:37:26 »
Looks like a ton of fun!
“Ride like the Wind” W.H.
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #32 on: Jan 12, 2019, 21:47:14 »
Hell ya man.. killer little bike
Live to Die, Die to Live
Offline Luugo86
« Reply #33 on: Jan 13, 2019, 12:49:29 »
What front end did you use for the swap on there? And was it an easy swap ?
Offline pitobread
« Reply #34 on: Jan 13, 2019, 23:53:16 »
It is a 96 or 97 GSXR-750 fork, A Suzuki GT-550 front hub that I changed the bearings out from the standard to fit the GSXR axle(an off the shelf bearing fit)  I had to machine the spacers.
The front brake is GSXR/Savage, the rotor is early CBR1100XX.  The hub has the same spacing so if you drill the rotor it will fit, it needs to be spaced out though, so I made an adapter instead of drilling that just rotates the pattern from M8 to M6
All-Balls bearings took care of the rest, I had to make a few little spacers to get the proper preload on the bearings.
I posted up a vidjeo on my Youtube of a quick ride on it today.
« Last Edit: Jan 13, 2019, 23:57:41 by pitobread »
