Author Topic: 1979 cb750f wheels on a '78 cb750f.  (Read 355 times)
Offline Rydog400f
« on: Jan 04, 2019, 15:35:30 »
Hello! I recently bought a 1978 honda cb750f. It came with a '79 cb750f aluminum front comstar rim and the original '78 rear steel comstar. I'm just wondering if anyone knows if the rear from a '79 is a direct swap. I'm running cb900f calipers and mounts so I'm guessing it is. The rims are the same size. Thanks!
Offline irk miller
Re: 1979 cb750f wheels on a '78 cb750f.
« Reply #1 on: Jan 04, 2019, 16:30:29 »
They swap over.  Sprockets are both 630, as well.
Offline Rydog400f
« Reply #2 on: Jan 04, 2019, 17:22:54 »
Great! Thanks!
Offline 50gary
  • Under the Limelight
« Reply #3 on: Feb 09, 2019, 16:01:11 »
I haven't been to the DTT in a while.  I did my Comstar conversion some years ago humm maybe 2009 or '10? Anyway, I used Suzuki GSXR 750 USD foks '06, a CB900 Comstar front hub and turned the I.D. of the hub to accept the larger modern axle bearings and made a new alu. inner spacer. I used a Comstar rear rim 2.15" x 18" and original front spokes (steel, non-reverse) and put it all back together with aircraft nuts/bolts/washers.  CNC a spacer adapter for the large Suzuki rotors to the CB hub, Galfer Superbike s/s lines  Changes the CX500 into a modern feeling bike and corrects virtually all the major faults of the bike.  Also did a nice disc brake (from drum) on the rear but that's another story.
  Cheers, 50gary
« Last Edit: Feb 09, 2019, 16:03:58 by 50gary »
Short track speedskating, cycling, guitars, motorcycles, juggling dynamite. I was born to laugh at Tornadoes.
