Author Topic: Yamaha DT2 Build - Smoke if you got 'em...  (Read 3548 times)
Online crazypj
Re: Yamaha DT2 Build - Smoke if you got 'em...
« Reply #80 on: Jun 04, 2019, 16:55:37 »
Never much of a fan of the 250 as it's a bit porky (lot of gravity in there)  a 360 or 400 drops right in and with minor port work plus exhaust you hav ea 120mph dirt bike  8) Those wheels maybe  direct from the MX bike, none flanged alloy was stock on them. They can be re-shaped pretty easy, I've done worse and made them look like-new. Just loosen off all the spokes in the bad area and anneal with a propane blowlamp. Put some hand soap on the inside rim flange, when it turns black your good to go with a dead-blow mallet or 4lb  'lump' hammer and wood blocks
That's always a possibility but you need a pickup that can withstand hot(ish) oil.
Is there a later model DT250 that came with CDI that would bolt on?  I did have a Hitachi single pickup system at one time (basically 1/2 a TZ system), but that had no lights.  Not cheap but how about an HPI small rotor set up or maybe a powerdynamo/Vape large external flywheel system.
https://hvccycle.net/yamaha-dt-rt-dt250-dt360-dt400-cdi-ignition-12v-180w-7238799dc/
https://www.hpi.be/item.php?item=210K059
     The later MX (monoshock) had electronic ignition. Don't remember exact spec but advance curve was totally different on the DT400M<X and stock it was bit of a slug. Fit 250 ignition plus Franconi or similar pipe and it will out accelerate a Kawasaki KX400 then run away at top end, even with stock carb (I think 34mm?)
« Last Edit: Jun 04, 2019, 17:16:26 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline bracketmaker
« Reply #81 on: Jun 15, 2019, 23:17:13 »
Started work on the stator for the DT2. Removed the coils for the lighting, charging, and ignition systems. We're going to a full 12V DC system, so all three coils will be rewound in series to create a single phase alternator.
did that stator. kept the ac ignition because its stupid simple and I can run without a battery. ungrounded the headlight stator and ran 2 phase full wave for the lights and horn. did not need to use the tail stator with the taps. removed it.
Offline teazer
« Reply #82 on: Jun 18, 2019, 19:24:48 »
Polaris - at least on some of their older sleds - ran AC to the lights and CDI ignition.  They had a simple two wire regulator too - probably just a zener diode to dump excess volts to melt snow.
Online crazypj
« Reply #83 on: Jun 19, 2019, 00:17:01 »
WOuld the rotating magnets in the flywheel not mess with the dyna pickups?  I know that people fit DYNA's to RD350s with an internal rotor and they seem to work OK.  I haven't tried one on an external flywheel.  Cheap enough to try.
Later DT250/400MX had electronic ignition
Brian Morgan, 1982
« Reply #84 on: Jun 20, 2019, 10:31:41 »
as well as early 360's
« Reply #85 on: Jun 21, 2019, 10:22:52 »
thats a common offroad setup. not just polaris, many dirtbikes and quads run ac lighting. the 2 wire ac regulator is a voltage clipper. I don't run this way because led's don't run ac. mark on the 2 stroke forum does. my kdx ran this way stock. rectified to half wave dc, regulated with a shunt regulator. (as opposed to floating ground to make street legal).
the rewound stator pic shows where this build is going. I just ungrounded the lighting coil and never looked back.
« Last Edit: Jun 21, 2019, 11:17:07 by bracketmaker »
