Author Topic: Yamaha DT2 Build - Smoke if you got 'em...  (Read 4865 times)
Offline Sonreir
  • Moderator
  • Oregon
Re: Yamaha DT2 Build - Smoke if you got 'em...
« Reply #70 on: May 01, 2019, 15:46:35 »
Toying with the idea... I need to find some room inside the cases.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline teazer
« Reply #71 on: May 02, 2019, 09:54:35 »
WOuld the rotating magnets in the flywheel not mess with the dyna pickups?  I know that people fit DYNA's to RD350s with an internal rotor and they seem to work OK.  I haven't tried one on an external flywheel.  Cheap enough to try.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #72 on: May 02, 2019, 11:06:23 »
That was my thinking, which is why space becomes an issue. Not sure where else to put it aside the rotor. Maybe something on the primary gear?
Offline teazer
« Reply #73 on: May 02, 2019, 19:08:00 »
That's always a possibility but you need a pickup that can withstand hot(ish) oil.
Is there a later model DT250 that came with CDI that would bolt on?  I did have a Hitachi single pickup system at one time (basically 1/2 a TZ system), but that had no lights.  Not cheap but how about an HPI small rotor set up or maybe a powerdynamo/Vape large external flywheel system.
https://hvccycle.net/yamaha-dt-rt-dt250-dt360-dt400-cdi-ignition-12v-180w-7238799dc/
https://www.hpi.be/item.php?item=210K059
Offline Sonreir
  • Moderator
  • Oregon
« Reply #74 on: May 08, 2019, 22:40:09 »
Got two of these bad boys wound. We'll see how it works out...
Offline Sonreir
  • Moderator
  • Oregon
« Reply #75 on: May 30, 2019, 13:19:42 »
Got the chamber back from Pacific Pipe Repair. They pulled the dents and laid on some fresh black coating. Not 100% sure what the coating is, but I'm assuming it'll hold up to the heat.
Offline SF
« Reply #76 on: May 30, 2019, 20:43:42 »
Looks new
72 R5
75 CB550 PROJECT
72/73 S2 RACE BIKE
72 CB350 MOM'S BIKE
Offline Sonreir
  • Moderator
  • Oregon
« Reply #77 on: Jun 04, 2019, 10:50:20 »
The decals for the front and side number plates came in. Looks pretty good, I think.
Offline JustinLonghorn
« Reply #78 on: Jun 04, 2019, 10:58:27 »
I can dig it.
Into The Sunset, CB750 build
TT500 the Animal
Offline Rider52
« Reply #79 on: Jun 04, 2019, 16:31:56 »
Looks great!
Member
AMA, VJMC, AMCA
Projects
74 Yamaha TX650
3 Harleys in constant state of sorrow and a Buell
1978 Yamaha Chappy 80 burning up the highway
Cut my motor in half Sportster to Shortster
Rodekilt Revitalization 1977 Honda CB750 http://www.dotheton.com/forum/index.php?topic=76749.new#new
