Author Topic: Dirtbag Challenge cb360  (Read 942 times)
Offline irk miller
Re: Dirtbag Challenge cb360
« Reply #10 on: Apr 19, 2019, 22:58:20 »
these pics taken at idle with no battery. could not figure out how to imbed a slideshow but the signals work perfectly.
exactly I didn't rewire this antique in a modern way with an sql40a rectifer 3 phase rectifier, nor did I make the shunt regulator.
exactly I won't post any more.
do not do what I do. wire your honda twin this way.
everyone please forget about the white stator wire it's not a phase, ac does not come out of it and it does not need to be rectified.
  I hope you'll still continue to post.  It's awesome that you figured out that you can wire a single phase alternator with a 3 phase rectifier.  Those wire colors I posted are how most of the aftermarket solid state and mosfet regulator/rectifiers are wired.  That was not meant to indicate the colors in the Honda harness.   The Honda harness has yellow, white, pink, green and red/white for the regulator and rectifier.
