Quantcast
Author Topic: Fiberglass fairing mountings  (Read 1942 times)
Offline canyoncarver
  • 'hacking is learning'
Re: Fiberglass fairing mountings
« Reply #10 on: Jun 19, 2019, 15:52:36 »
Similar to the post above but these are readily available.   I'm ordering some for my YZF race fairings.
https://www.ebay.com/itm/10X-Motorcycle-Rubber-Grommets-Bolt-Kit-For-Kawasaki-Yamaha-Suzuki-Honda-Fairing/264322892432
Offline TranceMachineVienna
« Reply #11 on: Jun 25, 2019, 04:09:28 »
Can't say I know the proper way to mount the aluminum if it's any different, but you might want to get you a transfer screw set, if you don't already have one.
https://www.amazon.com/gp/product/B01IUBRUTO/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
I dont quite understand what this is used for?
Maybe for transfering the holes of the mountings trough the fairing?
thanks
Offline irk miller
« Reply #12 on: Jun 25, 2019, 08:38:47 »
thanks
Yes.  They're pretty useful.  Anytime you want to mount something to existing threaded holes, let's say a lid to a box.  You screw those into your boxes threaded holes, lay you lid on top, then tap.  The transfer screw puts a dimple on the lid where you need to drill.  They're great for oddly shaped things that are difficult to measure for hole locations.
« Reply #13 on: Jul 15, 2019, 08:59:43 »
I've used speedy fasteners on windshields and fairings with great results.  The screw pulls a capture nut through the rubber flange and causes it to spread and grip the hole.
IŽm short before ordering a set of these....they look good and easy to use!Wont these screws come loose after some time?
Is there also a screw type with a cotter pin for removable parts of the fairing?
Offline teazer
« Reply #14 on: Jul 15, 2019, 10:37:19 »
Those rubber "well nuts" are great for windscreens but are not really suitable to mount a fairing to the bike.
Many race bikes used a mount that was a tube and over the end of that tube they had a plastic piece that was bolted to the fairing and was retained in/on the tube with a clip to allow for quick release.
http://www.meadspeed.com/resources/meadspeed/media-files/products/honda/rs125/fairing-mount/with-alloy-screw/main.jpg
In this picture you can see the top and side mounts that have teh nylon end caps in place
http://raresportbikesforsale.com/wp-content/uploads/2016/03/1998-Honda-RS125-R-Side.jpg
You can get some delrin parts machined like that or weld a short length of tube to a 10cm length of flat steel and glass that into the fairing. That should slip over the tubular mount you fabricate.
On a race bike, I would normally have a tube that runs across the frame and attached to the upper engine mounts.  At the front I would weld a tube to the steering head - pointing forwards.
On some I would bend a piece of flat aluminum and attach it to the engine side covers and use a 1/4 turn fastener.  On the street it's better to use rubber mounts and regular 6mm bolts.  Saving a few seconds on a street bike fairing removal isn't work the wear and tear with solid mounts.
CUSHION COWLING 94570-04A00 from a GSXR will work.  https://images.cmsnl.com/img/products/cushioncowling_big9457004A00-01_c626.jpg
Offline irk miller
« Reply #15 on: Jul 15, 2019, 10:50:20 »
I have an R69S with a fairing in my shop atm. Here’s how it’s fairing is mounted...
« Reply #16 on: Jul 18, 2019, 04:14:46 »
Thanks guys for the input!
The fairing is slowly coming along.
A lot of shaping sanding and all the good stuff.
I need to figure out how to finish the edges of the fairing. I had a chat with the engineer that will make the registration and  told me that the edges need at least 2.5mm 'rolling diameter'.
I ordered a big set of mounting hardware from ebay let's see what I'll be using.
Gesendet von meinem EML-L29 mit Tapatalk
