Quantcast
Author Topic: Impact wrench recommendations?  (Read 621 times)
Offline Jimbonaut
    • Lost Apostle
Re: Impact wrench recommendations?
« Reply #20 on: Oct 09, 2019, 12:08:10 »
I'm eyeing up this one -
$180 CAD and comes with battery and charger on promo - https://www.homedepot.ca/product/ridgid-18v-gen5x-brushless-4-mode-impact-wrench/1000785199
Offline Maritime
« Reply #21 on: Oct 09, 2019, 12:27:43 »
The rigid would be a good tool but not sure how the battery ones compare to a pneumatic.
Offline Jimbonaut
    • Lost Apostle
« Reply #22 on: Oct 09, 2019, 12:44:21 »
Me neither Mike.  But this thing has up to 450ft lbs of torque which has gotta be enough, no?
Offline Maritime
« Reply #23 on: Oct 09, 2019, 12:45:43 »
Probably. I'm planning to get one someday soon so let me know how you like it.
Offline Jimbonaut
    • Lost Apostle
« Reply #24 on: Oct 09, 2019, 13:16:04 »
Will do.  The promo on at Home Depot (until end of Oct) buys you the impact for $180, and you get a battery and charger with it thrown in (worth $150).  I'll let you know how it goes.
Offline Maritime
« Reply #25 on: Oct 09, 2019, 13:26:23 »
Kool, I have a Makita Li Ion drill with 2 5.0 AH batteries so I'll likely get an impact that uses the same packs but that will depend on if I can get one that cheap.
Offline irk miller
« Reply #26 on: Oct 09, 2019, 18:17:11 »
The only thing I ever use an impact driver (the air or motorized kind) for is installing car wheels.  The manual ones I posted do well for loosening and tightening.  Plus, most motorcycle stuff has torque numbers, so you're not using an impact driver for much.
Offline Maritime
« Reply #27 on: Oct 09, 2019, 18:31:56 »
100% impact is for loosening only. Unless steel wheels on a car then just giv er
Offline Jimbonaut
    • Lost Apostle
« Reply #28 on: Oct 09, 2019, 20:44:20 »
Yeah I totally hear you guys.  I won't be using the thing for tightening stuff up, just for breaking loose bolts and the like.  There have been a few occasions where a bolt has been my undoing, however -
- no longer.  This thing is the absolute dogs bollocks, got the clutch nut off without blinking.  Winter tire changes are going to be a walk in the park with this thing, and with 450ft lbs of torque I can't imagine many situations where I'd need more.  Unless that build-an-Eiffel-tower itch needs scratching.
« Last Edit: Oct 09, 2019, 20:49:18 by Jimbonaut »
Offline Pete12
« Reply #29 on: Oct 10, 2019, 06:24:27 »
I've got a Chicago Pneumatic impact wrench running on continuous 105psi and a Milwaukee battery powered impact wrench and the Milwaukee shits on the CP, so much so that I haven't used the air one in a couple of years.
