CCRider
Coast to Coast
Hi everyone,
Well I'm very close to starting a "Big Arse Project" thread for my CB450 build, but before getting into that, I thought I'd do a write-up on my seat build for the project.
The materials are all about the same as I used on my tank, so refer to http://dotheton.com/index.php?topic=6339.0 for that.
First step, of course, was to grind all of the original seat mounting tabs off of the frame:
I'm going to keep the stock rear fender, incorporate the brake light into the seat and mount the battery and electronics under the seat cowl, so I came up with a battery tray that will mount to the rear frame bow and and the brake light mounting holes in the fender.
I made a cardboard mock-up of the battery I planned to buy for sizing:
I bridged the area between the frame bow and brake light mounting with cardboard and covered it with tape:
I waxed the taped form and applied about four layers of fiberglass and epoxy:
After everything cured, I removed all the tape, repositioned the tray on the frame and drilled the mounting holes:
Next the tray was marked and trimmed to the final shape:
Later on I'll lay up a fiberglass battery box that will bond to the top of the tray.
CC
CC
