Welcome, Guest. Please login or register.
Did you miss your activation email?
  184037 Posts in 17448 Topics by 6898 Members Latest Member: vbroom
Dime City Cycles
* HOME HELP LOGIN REGISTER LATEST_POSTS DO_THE_TON_SHOP CONTACT_US CHAT
Flying Squirrel Black Dice Cafe
« previous next »
Pages: 1 2 [3] 4 Go Down Print
Author Topic: My idea for making a Fiber Glass Tank but I need INPUT!!!!  (Read 2507 times)
sxecafe
Revered Caff Racer Idol
Offline
You think the Carpet Pissers did this?
« Reply #20 on: Apr 26, 2010, 23:32:02 »
Changing the thread name.
Logged
DO THE TON
Flying Squirrel
 Logged
rockcitycafe
slack-jawed yokel!! spends too much time online
Offline
WWW
« Reply #21 on: May 11, 2010, 20:46:34 »
I'd actually keep the foam without the masking tape, the cloth won't want to stick to it when you're laminating and for whatever value it has in getting the foam plug out, it's used up in the extra pain in the ass it will be when doing the glass.  secondly, I'd go back and really try to get your foam perfect, as far as matching radii and symmetry overall, that's the stuff you can't fix when you get the fiberglass on.   always remember the 6 p's - proper preparation prevents piss poor performance Wink
Logged
www.roccitycafe.com - Alloy, fiberglass and carbon fiber seats, tanks, fenders, custom race exhausts ... cool stuff in general
sxecafe
Offline
« Reply #22 on: May 12, 2010, 11:45:00 »
Thanks for the info, bud.
I have kinda changed my approach on this thing. I wanted to make this a plug so I can dup it if need be. When laying up all the tooling gel etc., will the tape still cause a problem? I just didnt want it to melt when I applied any resin.
Also, just so we are on the same page, are you referring to the front of the tank? I could use some help in figuring out symmetry on this thing. I think I'm in too far and need outside perspective from someone who's heads not in the tank like mine to get it perfect.
Logged
rockcitycafe
Offline
WWW
« Reply #23 on: May 12, 2010, 13:57:37 »
for symmetry, lay up a center line on the tank, and take measurements of each side from that line, they should be the same, if not, add or subtract material where needed... as far as using it as a plug, you mention using tooling gel?  were you planning on putting tooling gelcoat on the tape itself?  generally a plug is a perfect model of the part you want to make, and for a one off, just make the part, there's no point in going through all the work to get a perfect plug just to make one part from a mold, unless you need to build it in some exotic material with really high tolerances for weight/reinforcement patterns, etc.
Logged
sxecafe
Offline
« Reply #24 on: May 12, 2010, 15:47:48 »
my thoughts were that just in case I dump the bike... I didnt want to be out of a tank and have to start from scratch shaping foam again.
I lined up the templates I used to make the shape. For the most part I think Im in line fairly well. I was thought you had noticed something in particular but if its a general statement, I def appreciate it from someone with the skills you have.
Logged
DO THE TON
 Logged
dcmspikes
Walkin LEGEND...
Offline
WWW
« Reply #25 on: May 12, 2010, 19:58:29 »
get yourself a contour gauge  for making each side symmetrical
http://www.lowes.com/pd_14154-56005-837_0_?productId=1016371&Ntt=contour%20gauge&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=contour%20gauge
Logged
If you arent doing it yourself, is it really yours?
sxecafe
Offline
« Reply #26 on: May 12, 2010, 20:40:49 »
Do you think I'll have issues removing the mold if I do it in one piece because of the contours of the side?
Logged
rockcitycafe
Offline
WWW
« Reply #27 on: May 12, 2010, 20:50:22 »
most people plan to not drop the bike Smiley
if you have undercuts on the side of the part, you will not get it out of the mold
Logged
sxecafe
Offline
« Reply #28 on: May 12, 2010, 20:53:43 »
So how about halving the mold, say one from the front and one from the back, when I start and joining then together after they are released?
Logged
sxecafe
Offline
« Reply #29 on: May 12, 2010, 20:55:32 »
I also dont WANT to do this... but you never know  Wink... just to be on the safe side since its a one off and making molds is not terribly expensive I figured why not try to preserve it some how.
Logged
Pages: 1 2 [3] 4 Go Up Print
« previous next »
Jump to:
Browse other personalized gifts from Zazzle.
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006, Simple Machines LLC
Black22 design by Bloc
Valid XHTML 1.0! Valid CSS!
Page created in 0.323 seconds with 27 queries.
