Re: 2001 Yamaha SR250 - Deus inspired Cafe Racer
Hi Guys,
I have no idea what this bike will end up looking like. Just really little things like the frame's angles could make it look deranged.
Here's and update and some more pics:
Took apart the whole bike
Re-wiring is a nightmare
Removed all the wiring. Took about 2 hours. Slowly removed, labelled, used permanent marker to draw symbols on the connectors like A, B, C, so I remember how they re-connect. Learnt that about 50 individual wires cling to each other behind the headlight.
Painted Exhaust - Experimentally
- Wire Wheel
- No Primer
- 5 x VHT Wrinkle Plus Paint
- Left it for 2 days untouched
Wrinkle turned out awesome. 2 mm tight crinkles.
Problem: It chipped off almost instantly, when I mounted the exhaust back on... Definately need Primer! I supposed paint just doesnt chrome OR it needed some heat fixing...
Painted Swing Arm - Experimentally.
- Got some cardboard boxes from Franklins and masking taped together a little booth.
- Used coat hangers bent into hooks with string to hand the swing arm up.
- 400 Grit Wet/Dry sanded it down in a # pattern
- Pine-o-Clean Detergent
- Preen Degreaser
- 5 x 'K&H Etch Primer' - White - But would probably go with black next time! As you can't see it white blotches when the paint chips off. Ideally it shouldn't but just in case! Sprayed in # pattern following can instructions.
- Preen Degreaser
- 3 x 'K&H Gloss Black Finish' - Enamel
Prime coat looks awesome. Smooth, even. roughed it up with sand paper. The black... massive nightmare.... I sprayed the rear of the swing arm first, sprayed just enough so you can still see the white speckled through. Then sprayed another coat to seal it all in black. It looked great. Then sprayed the front, omfg. First shot, I drenched it in black, thinking it would be fine... It started to bubble like chicken pox all over the place.
Sanded it the bubbles down, thinking it was the paint's problem. Then shot another coat. Same thing. Looked fine first 3 secs, then it started to bubble and drool. I assume I didnt degrease it properly on the prime layer...
Does anyone have any clues to why the paint bubbled and drooled?
Tank - Stripped, Sanded, Polished and buff
- 1L - Diggers Paint stripper
- Glad wrap to seal the stripper in and get the most out of it. Apparently you can double the use of it.
- The paint is pretty thin... probably about 5 coats I can imagine, because it came off pretty easily.
PHOTOS SOON
Removed the engine ready to paint.
Started unscrewing some of the cross head screws on the side covers and because my drill is cheap (Ozito $35 - 12V), its pathetic low RPMs ruided the screw heads... Not to mention it's NiCd battery takes forever to recharge, so I get impatient and use it before it fully recharges. Turns out the battery is now permanently flat. Like I mentioned at the start of this blog - I have no idea...
So, now I have about 3 screws that I can't remove... I bought a screw extractor from Bunnings for about $30 and it drilled in about 3mm, gripped on to the inside of the screw, but it still would budge. Now I have a new drill...
Angle grinded off pillion pegs.
- $70 - Ozito Angel Grinder - 100mm, 850 Watt
- $3 - 100mm Steel Cutting Disc - Bought the thinnest one available from Bunnings
- PICTURES COMING SOON
This was pretty cool to see the sparks flying in all directions. Scared the crap out of me at first. It's quite threatening when your supporting hand is so close to a blade when you know it can easily cut off steel frames... Make sure you wear long pants, shoes, gloves and long sleeves that cover your wrist area... the sparks singed my skin...
Removed Tyre from Rear Wheel
- 3 Screw drivers
- 1 long pole with a flattened end
- My mate made a 20min video of me doing it (because apparently I looked like a monkey on Discovery Channel). If your interested let me know and I'll post it.
Once about 15cm of the tyre pops over the rim you can start sliding the screwdrivers down the edge of the rim and the tyre pops out (half anyway). Then you need to the same on the other side of the tyre. Spent about 2 hours prying the tyre off the wheel's rim. In the process I may have bent the rim. About a 1 inch area has lifted slightly revealing crackled chrome. Definately not going to bother with the front tyre... I'll just take it to a tyre shop.
NEW TYRES
Ordered some new tyres from Deus Ex Machina, which they will fit for me at the shop. I'm not 100% about sizing, as I want the largest possible rear and a slim front without compromising the stance too much into a forward leaning bike. Originally I wanted to fit a rear 450-18, but the tyre will rub the chain. I also wanted a 300-19 front, but the apparently slim tyres feel dents in the road. However you don't want to go too big otherwise you can't steer at all!
Current Tyres - Stock
- Front: Pirelli - 90/90-19 - 3.65" Wide, 26" Diameter
- Rear: Pirelli - 350-18 - 4" Wide, 25" Diameter
New Tyres
- Front: Avon Speedmasters - 325-19 - 3.4" Wide, 25.9" Diameter
- Rear: Firestone 400-18 - 4.25 Wide, 26.57 Diameter
So, in essence I will keep the front just as tall (0.1" lower), but raise the rear (1.57" higher) due to the wider rear tyre. There's about 0.45" before the rear tyre's diameter rubs the inside of the swing arm. Swing arm is 8" wide (at the centre of the wheel), which leaves about 1.87" each side of the tyre for turns. Apparently tyres balloon out when you ride. Not sure what will happen then... Hopefully that will work fine. What do you guys think?
De-Spoked Rear Front Wheel
- WD40
- Drill with Flat Screw Tip
- Slowly unscrew
- Twist the Drill so it is positioned to hit the spoke nipple. So, if the nipple is positioned this way (|), I will position the Screw driver tip in this position (/) while being inside the nipple. Do that about 5 times and the nipple starts to freely twist off. This is so that when the WD40 soaks in through the stubborn rusted nipples, it twists the nipple with a millimeter's worth of impact... It seemed to work better than doing it normally, which actually ruined one of the nipple heads.
Some rusted parts where the nipples attached to the spokes...
Parts of the rim WERE cleaned (so I thought, but rust slowly built up over the past few days...). It's still about 10ish degrees in the evening in Sydney, so I supposed there's been a bit of humidity in my garage. Lucky I didn't prime those wheels impulsively!
Paint stripped the frame
- 1/4 tin of paint stripper...
- Wire wheel
- Be careful of the chassis plates. Maybe mask them off prior...
- Paint on the frame was REALLY thin, you could scratch it off lightly with a screw driver. I imagine it would only have been about 1 or 2 coats... Then again, the swing arm seemed quite tough to not scratch on the brake light spring... Or perhaps it was just many coats of thinned out paint, so it made even coverage without having to look thick (or scratch off noticeably).
Shopping for a small headlight - 4"-5.5"
I'm looking for something small, slightly bell shaped, chrome rim and ideally black.
Something slightly narrower than the forks, but not so disproportionately tiny... And, include a bottom mount. So far Posh seems to have a nice one. I assume it will be atleast $120-200.
Ebay has lots, but they don't come with bottom mounts...
Anyone know where to find these kind of headlights for cheap?
Thinking about the seat...
Fabricate a fibreglass seat and upholster it with leather (or buy a seat, depending which is more cost efficient)
Thinking about tearing up an old leather couch (like the ones you see thrown on the street) and use the leather to get a rustic vintage look since it already has distress marks from being sat on. I really don't dig the shiny new leather on some after market seats...
- Buy some neoprene from Clark Rubber
- Mark out the stitch pattern (pleats and edges)
- Use a thick needle and thick thread
- Hand stitch it through
- Staple gun it to the bottom of the seat I end up making...
Buy mini switches for controls
Jay Car has little toggle switches On-off-on and push to start buttons! Which I will need to drill holes into the handle bars to wire through... Will the bars snap??? Hopefully not a big deal... The thought is scary though.
An internal throttle would be nice to have. The cheapest was $134 but unfortunately they're pretty much all for 1" handle bars.
Does anyone know where I can find an internal throttle for 7/8" bars?
Shorten Front Forks
To lower the front end, I loosened the triple trees. Bottom first, then VERY slowly loosened the top. I let them come up as much as possible (about 1") and then tightened them back up.
I suppose this is only short term, as I would like to angle grind the forks shorter. Apparently inside the fork there is an pole. And that pole is what needs to be shortened.
Does anyone know how I get to those poles inside the fork?
Paint Tank
I'm digging the whole polished steel look of the tank that I probably won't paint it just yet. After watching the bike start to rust when I hosed down the just paint stripped frame, I realise that steel rusts like a motherf*cker. Within 1 hour it had patches of brown oxidisation appear in patches where the water didn't drain off. I toweled it off straight away, WD40's and wire wheeled those parts! *Phew....*
I like VHT paint very much so. It's got a great nozzle, and when you make a mistake and go too close, you just can't notice! Even when you have over spray and it sprinkles onto the 1 minute dried paint, it just blends right in! Bear in mind, I am comparing to K&H, which I found was not very forgiving. I can't find a
VHT Clear Coat
Could anyone recommend a good clear coat that they have used on a steel tank before?
Thanks for reading!
Best wishes,
Damo
