jonescafe72
Well, things have kind of stagnated with the holidays all around. I've been polishing (still), and cleaning everything that I can. Most of the parts are ready for blasting, and paint. The engine is all cleaned up, and partially reassembled. I'm still trying to find a center-stand that will fit. I need to lose the side stand. The bracket for it is horrendously ugly. It is an angled plate that looks like an afterthought. It's welded to the frame, and hangs out over the top of the exhaust, and it's on the right side. I think a small-ish center-stand will look better, and the brackets are already on the bottom of the frame. After I source one of them, and weld on a couple of brackets for more support for the sub-frame, the frame will be ready but it's too cold to paint, and I don't think the wife would appreciate it if I brought the engine into the utility room to spray a couple of coats on. I got some Duplicolor ceramic high temp aluminum color for the engine, and some black for the cylinder head. Everything else for the engine has been polished. I think it will look pretty good. Would a couple of tarps hung from the garage ceiling and a small propane heater provide enough heat for painting in the winter? Has anyone done this with positive results? I'm really anxious to get some stuff put back together.
