1967 BSA Rear Wheel Alignment issues???
Jack Burton
Everything seems to be in place. The spacers are correct, I believe. The owner told me this is correct and he rode it for a year like this????????? Is this a spoke issue? Offset?
If you had the wheel rebuilt I would bet it is the offest (spokes) that are the problem. If that's the problem and not the spacers it is simple enough to remedy. Just loosen all of the spokes half a turn on the opposite side of the wheel that you want to move over then tighten the other side. Keep doing this until the wheel is centered. Just make sure if you move the rim over that you still have clearance between the chain an the tyre.
