1971 cb 350
Smoking Star
Hi everyone, I have had this bike all winter and have not been able to work on it, seeing how it has been bitter cold here in Iowa.
I have to decided to suck it up and get out in my garage (with a small space heater, to keep me warm) and just get it done.
I want to be riding within the next month or so, and I have the capital to do so. I’m just lacking the know-how to do it.
About 3 months ago I was trying to break into the motor and I stripped a few screws. I recently acquired a Dermal tool and
since then have Changed all screws into flatheads, then used an impact screw driver to release them. They have all been replaced with
allen's.
after opening the oil filter cover... I found no oil filter...? I don’t know what that’s all about. the clutch plates were kind of stuck together so i took
them all off and put them back in. Didn’t help the fact that my clutch wont disengage though.
Here She is.
I plan on getting her Road worthy by the end of next month. I will worry about cosmetics later.
It looks like she has low miles but Im not sure if its telling the truth.
( like a girl who tells you she has only slept with half the guys she has, and you know its more)
I cleaned out the tank with electorlosis and for the most part its clean.
I was messing around with the points, shinning them up and such and
I dont know how to adjust them so they are working right, the manual didnt really say
how to install them.
I got a gauge for setting the timing but Im not quite sure how to set its. I know i have to open
the 19mm bolt but after that im lost...
Awesome! Can't wait to see what you do with it. I'm currently in the same boat but I haven't tapped into the engine yet. I'm currently trying to figure out what the heck is wrong with the electrical system. Keep us updated!
I found someone selling a few cb 360 parts on craigs list and I Jumped at them I picked up a few things from a guy out in the middle of nowhere Iowa,Here they are.
nothing alittle electolosis* sp im drunk
Not a single dent, paint almost perfect!
up for sale
I dont need the side covers or the seat, But that gas tank is "Cherry" im def using that. I wanted to use the
Diaphram from the carbs but i dont think they will match up or I cant get them off the shaft thingie.
Yeah, those carbs won't just fit right up. Also, the diaphrams from the 360 will not fit the 350.
The inside of the tank looks a bit...dirty. I've cleaned the inside of a tank with diluted muratic acid. Be careful not to get it on the paint, and be sure to remove the petcock :)
--Chris
I like the paint color on the first tank,but like the graphics/sticker on the second tank much better. It really is a cool looking stripe.
I build this little guy from my Olive Garden swipe card, that i have about a million of.
When i went to set the float level of 19-20mm the only way I could achieve this was to about have the
floats pushed up against the roof of the float bowl, This dosent seem to be right.... It could be I guess,
seeing as how I have never done this before.
cleaning out the tank.... Hipe it dosent take to long.
Homany bottles of svedka full of water dose it take to fill a cb 360 gas tank!?
anyone set there float hight recently that has any insight into my situation?
