1971 CB350 K3 Project
Paddlefoot64
Recently new to forum. Purchased project bike from Deviant1 of Gulf Shores. It is a 1971 CB350, partially converted to Cafe Racer. Tank needs painting. Seat needs finishing and attachment. Rear sets need attaching and may have to be replaced (kind of clunky mounting brackets, not sure of maker). Is not running yet, but I have replaced fuel lines, battery and will change oil before attempting. Inside of tank is not too bad. Will probably seal before painting tank. Tires are fairly new Avon RR. Some rust on mufflers and wheels/spokes. Am working on removing rust and if I can't will have Mike Porter of Powder Coat Junction coat them. He also will help replace right upper shock mount bolt which is too short to attach nut.
Added NOS ignition switch today.
Very cool - I just picked up a '71 CB350 about 10 days ago. :) Mine's still much more stock than yours, but I've got it apart and have started cleaning things and figuring out how to reconfigure some stuff.
Installed new battery, charged it up and found that starter turns motor over. Installed new petcock, fuel lines, put small amount of gas in tank. Sanded points and checked gap. Plugs, when removed, create spark against cylinder head. Would not start, but would run for about 30 seconds after using starter fluid with throttle wide open.
Removed float bowl on right carb, removed jets. Cleaned jets, bowl, drain screw, etc.
Then she fired up and ran! No lights, but took her around the block in first gear. Only brake is front brake. Nevertheless it proves she lives. I'll probably get Mikuni VM30s as Keihins need total rebuild to work well and have two float bowl screws threads stripped.
8)
