1971 cb350 Project, Get it running.
Smoking Star
Picked up a 1971 cb350 with 9k miles on it 3 days ago, AND I KNOW NOTHING.... Nothing about motorcycles. I dont even have my danm licence. I figured I would learn how to fix this danm thing then learn how to ride it. rather then the other way around.
I know you need gas air and a spark for this danm thing to run sooo. I cleaned the carbs In the process of cleaning the airfilters
( if i can figure out how not to distroy them) and I bought a batterie charged it and hooked it up. Lights work blinkers work, but No spark. What do I do now?!
The first thing you do is buy a repair manual for the bike. They can be had online or look in the section of this forum for a manual. So many people are running the same bike one is more than likely available for free download. If the bike has been sitting for awhile you must disassemble the carbs and clean everything, I mean everything, every orifice and jet- everything!!! The manual will show you how, it's not as hard as it sounds. then a vlave adjustment, then change all the lubricants and filters ( including the air filter unless it's a K&N), drain, refill and bleed the brakes if the bike has disc brakes if drums adjust as per manual. Just go slow, take your time and have fun learning about your bike, just remember your life will depend on the work you do on the machine now and in the future. Oh, and buy a decent helmet, not some 40-50 buck piece of crap spend at least 100$-How much is your brain worth? Have fun and do the job right, I'm sure many people on this fine forum will be willing to help!
Terry Monday
J'ville, Fl.
Sorry, just remembered something. Drain the gas tank and refill with fresh high octane and add some Seafoam to the gas to help clean the crap out of the tank. Seafoam can be got at any auto parts store. Then clean the petcocks better yet rebuild them!
Terry Monday
J'Ville, Fl.
I'm sorry but I really can't answer as to why you aren't getting spark to the plugs, But you could try replaceing the spark plug wires and caps from the coils down to the plugs. Replace the condenser while your at it. As for the points, I'm more familar with Yamaha 650 twins and airhead Beemers rather than Hondas. but I was having the same kind of problems with an old XS650 and eventually replaced the entire ignition system, battery, and battery cables. The repair manuals by either Clymer or Haines will have trouble shooting advice and will really help you on your way. any the hell with cleaning the points just replace them, they're cheap, you may also have to get a volt/ohm meter and check the coils to be sure they are working within specifications. but make no mistake about it, do all the basic maintiance, you can never be sure about a PO nomater what they told you.
Terry Monday
J'ville, Fl.
No spark? Then it could be your coils, plug wires, spark plugs, bad points. Probably a good idea to just replace all this stuff. You will eventually anyway.
Some people buy Uni filters, some rebuild the stock filter with new paper from a filter in a store ( i did this with good results), or replace them with NOS (very expensive.)
You might try blowing them out with compressed air.
Thanks for the help Jonny5. I really dont know anything about motorcycles,and im using this bike as a learning experience.
Do some searching for the shop manual. There's a pdf of it floating around on the net. It's invaluable.
I got the repair manual for the 250-350. I got the bike to start. just did alittle shinning up of the points.it would start for alittle then die. I could only get it to start for 3-6 seconds, and if i tryed to gas it, it died. Atleast it started,right?! Next step after rebuilding the filters should i rebuild the carbs?
That could be a lot of things, but sounds like the timing is off. Meijer sells a decent timing light for about $35. I think the same light can be found at Autozone. You can set the timing so quickly with the light. A really good investment. Especially with these old bikes with points and the timing needs to be set a few times per year.
Does anyone know where to find the manual on the net for this...I've yet to find one 'cause I have no "finding the manual on the net skills" : I've tried but to no avail.
Smokinstar. Disassemble, and thorouly clean your carbs.! Bike should run fine after that!!!!! You have a plugged up pilot circuit! DO NOT touch the timing!!!! Here's another little thing to remember when working on problems. This is for everyone, not just smokinstar. KISS!!!!!! Keep It Simple Stupid.
I have an old CB125 and aside from being a 6 volt electrical system and mine being smaller than yours they're very similar. I've actually encountered a lot of the same problems. Like most of the other guys said, clean your carbs first and change your points. Adjust your points it's really simple. if you're a smoker use the cellophane from your cigarette package otherwise get a feeler gauge. If i remeber correctly the gap for your points should be somewhere between .014 and .016. When you crank the bike you should see a nice blue spark between the points. You can swap out your condenser and coil if you need to but since you've already gotten the bike to turn over it doesn't sound like you need to. My bike actually started to backfire because of poor points. For the simple task of getting it running I wouldn't worry about air filters just yet and most old Hondas basically have a K&N filter. It's probably wrapped in some really crappy foam but when you open the air box the element should be very similar. Just clean it with some solvent let it dry and soak it in oil same as a K&N. Once you get the air filter back on you can worry about adjusting the carbs. Should idle somewhere between 9-1100 rpms.
