1974 CB360 Steering Bearing Removal and Fitting
In my case, the races were damaged. New BB's would not work. The difference with tapered rollers is the surface area supporting the weight is a lot larger than ball bearings. That is one reason they will last longer. The forces are distributed over a much larger area so they are less likely to dimple.
If you need races, tapered rollers are higher performance.
From a mechanical engineering point of view, if the BB's are worn out, the races are too. You should replace both.
Sent from planet Earth using mysterious electronic devices.
With that in mind- I know tapered handle axial and thrust, while balls only handle axial. Are we dealing with both here? I only replaced balls because the same size ball is used in several places on the bike, so I had to order them anyway. I'm also under the impression that the raceways are harder then the ball, so the balls will wear faster. Also, my bike only had 6,000 miles on it. What I'm trying to understand, I suppose, is application and practicality. In my experience, the conversation between balls and tapers was always related to axles, like drive shafts, where heat and rpm were factors.
the ball bearings sets in a steering head are not a radial ball bearing they are angular contact (just like a tapered bearing) and must be used in back to back pairs to handle radial loads and thrust loads in both directions(just like a tapered bearing SET)
many late model bikes and sportbikes , even motogp bikes use angular contact BALL bearings, they are superior because they have less drag,they rotate more freely.....
they do have much bigger balls though than our vintage stuff
This has to be one of the most surprising threads I have read here. Most every old Japanese bike I have ever seen has head bearings which deal properly with axial loads only. A rather dreadful choice from an engineering perspective, when you consider the top bearing has hardly any axial loading at all, and the bottom mostly only needs to support the weight of the bike (and only the front portion at that, though the transient loading on bumps can be a pretty good lick). The big loads that you would notice are the radial loads applied to the system under hard braking (made a lot steeper when you add bumps). The two parallel races of these bearings provide a good surface contact area for axial loads, but very little for radial loads. Unless the clamping force applied to the bearing components is very high indeed, the upper bearing becomes very noticeably loose under hard braking, which adds compression to the lower bearing, and subtracts compression from the upper. With the full weight of the machine working against the braking force of the front wheel, the top of the steering shaft is loaded quite severely towards the front of the bike. If the assembly is properly tight, this motion may not be especially evident in normal driving, but if you push hard enough, it very likely will be. You can see this pretty easily for yourself by simply loosening up the compression in the bearing assembly. Back the nut off just a bit, and the steering will still turn smooth and feel pretty solid, but roll the bike forward and suddenly apply the front brake, and you will see motion between the top of the steering shaft and the frame. Tapered roller bearings are intended to deal with this very sort of radial loading. And even if quite loose, the amount of "slack" in the system is very small when compared to the parallel face bearings they are replacing. If you believe the stock bearings are fine, you may be right if you are very easy riding your bike. If you do ride it hard, throw in the tapered rollers, and I would bet the strongest naysayer will notice an improvement when riding hard. Tapered rollers do present considerable more drag, but not a problem if properly adjusted. Those thinking the tapered rollers reduce the dreaded speed wobble are likely experiencing the improvement not because of the bearings per se, but because of the additional drag. It actually takes very, very little energy to keep the oscillation from starting and growing big enough to notice, and the steering bearings being a bit tight could accomplish this.
i feel that tapered bearings are an upgrade over the stock vintage small ball angular contact bearings, but what all the late model sportbikes and motogp bikes use which is large diameter balls and races is the best way to go,however they are not really readilly available for the old bikes
yea, the old stuff is only set up for axial loads, and it's asking a lot for those little bitty balls to stay in those absurdly shallow races with my fat ass at the helm.
The problem with bearings in a steering head application is that they only move between 90-120 degrees in their entire life, but most of the time they stay in the one spot.
Which means they wear out in the one spot (IE: get notchy). That's why tapered bearings are more durable because they spread that load over a larger surfaced area roller as opposed to a ball.
Another major factor besides not needing to replace tapered bearings hardly ever is... tapered bearings when you take the steering stem out you don't hear those little bb's drop everywhere! No thanks. It takes too long to try and find those.
