1975 cb 360 dependability
cafebelan
Hollywood Cycles
I have a 1975 cb 360 stock motor 8k miles. Are they known for being good or bad motors. Any stories welcomed.
meh
built like a paper bag compared to the 350...
tensioner was a better design though, but that's just about it
For putting around town, their a fine bike. If you want to do anything really fun with them, open the wallet and start designing. Theres no real aftermarket as theyre kinda the bastard twin of the Honda line...
VonYinzer said:
For putting around town, their a fine bike. theyre kinda the bastard twin of the Honda line...
Yea, i have a 74, and it runs, and for anything below 55, it is fine, but any thing north of that, get the 750+ not to mention, this thing will rattle your arse like a cheep can of spray paint.
real vibration machine, my motor has 10k on it, and it will start in 2-3 kicks.
Great if used as designed, around town.
They can cope with 10,000rpm indefinitely for a few seconds at a time but sustained high rpm use will destroy cylinder head within 100~150 miles.
Frame is a lot better than CB350, 180 crank should be smoother but isn't (?)
Forks are easier to work on when you need seals, bronze swing arm bearings a good idea.
first thing I'd do is open up the top end and inspect the cam bearing faces and cam lobes, if they're nice and shiny, and there aren't any streaks or grooves on them, than that's a good sign. second thing I'd do is remove the oil pump and inspect the internals, if they show signs of pitting or scratching, replace them, bikebandit.com has new parts available for them. that should take care of you as far as longevity goes, don't run it on the interstate though, until you do some further work...
