1975 CB200T Starter Button?
pj_elia
Does anyone know if all the starter buttons on the larger CB's from this era are the same as the CB200 starter button. I can't find a part number specifically for the button and all the ones I find for sale don't mention the CB200. Thanks
The starter on units without a headlight on off switch engage the solenoid using 12V. The headlight is wired through the start switch too...Push the button, headlight goes out, starter engages.
If the pod has a headlight on/off switch, hen the starter engages the starter by grounding the wire from the solenoid.
If you mix them up, you can short the harness....
This happened in 1975 as the US DOT laws required headlights on all the time.
