1976 CB400SS four / starting problems
Mule76
Hello everyone,
I'm hoping to find some answers as to why my CB400 will not start anymore.
I've started it a few times after I changed all the wiring and it was allready a bit of a challenge as I had to hook it up to my car since my battery didn't have enough starting capacity. Anyway when it's turning there's no problem, I can adjust the carbs so the engine runs at 1200 rpm and when it's hot, it starts right away.
So I swapped out my battery for one that has 150Ah starting capacity and changed my spark plugs for same model Iridium spark plugs because they burn on a wider spectrum.
When I started after the swap, solely on starter engine, you could already hear the difference on the rate in which the starter motor was turning that there was more power, it started right away.
Stopped it on the dead man's switch and started again, it took a bit longer but it started again, then I used my choke and it stopped practically right then.
I have not been able to start it again since.
I have spark with new plugs, battery's new, my carbs are cleaned,every bowl has 45ml of fuel in them so I have fuel.
The carb model is Keihin 054A, and there's just one screw for adjusting the mixture, and there seems to be a limiter on it (see pic). I was learned to close the air/fuel mixture, then turn it out for a turn and a half when you start adjusting carbs. Which is not possible on this model. I tried adjusting it by quarts, there's no difference, I can't get it to start. I'm not 100% on my ignition timing, but when we started it with the car battery we brought it as close to a good start that we could visually. And since it started right away with the new battery/plugs I don't think that's the problem.
I have a fully open exhaust, maybe it's getting too much fuel and I need to re-jet ?
Plugs are a bit wet when I get them out, tried drying them out and restart, nothing.
I'll post a pic of the old plugs which seem a bit blackish.
I'm a bit in doubt at the moment so please help, thanks.
The floats are adjusted to spec, needles are clean.
You could potentially have flooded the comp chambers with fuel when choked and repeatedly trying to start. When attempting to troubleshoot a bike I always pull all the plugs and turn the motor over a few times to purge any excess fuel
I realize the plug shows a rich condition, is there anyone that has same kind of carbs and can confirm that this screw with limiter is the air/fuel mixture?
I hope these blackish plugs don't mean what i read here :
I tried turning the engine without plugs, there was no ejection of anything, no oil , no fuel.
Don't think I need to re-do my top end !
TRied the spark on my plugs again and guess what ? No spark at all, not on the new, not on the old plugs, fuses are good.
Could it be that those new plugs are already wasted ??
Or do I change my coils ? That seems the more logic anyway.
Battery was fully charged and I had all 4 plugs hangin' against the block, tried all of 'em separate, no spark.
I think many, if not all carbs, on bikes back then had limiters on the air/fuel mixture screws but they limited the carbs to a lean condition in order to make them run cleaner. Someone else may be able to confirm this.
There should be only two screws to adjust on this carb, one raises the slide to set the idle speed and the other is the air mixture screw, I am pretty sure this is the idle mixture screw but it should only be limited to a leaner condition so I am guessing something else is giving you a rich mixture.
That carb looks pretty dirty on the outside. The air mixture screw controls the amount of air entering the carb at idle so if that part of your carb is gummed up then you would get a rich condition at idle. Are you sure that the carb is completely cleaned?
@carbsandcylinders yeah, spotless on the inside, cleaned the cups in a parts washer and cleaned the needles with carbclean, blew through every opening with carbclean and compressed air. Should be all good.
Indeed as you say only two screws, big one for idle and the one in the pic.
If I need to adjust this will mean small twists on the air/fuel mixture screw, that will be a challenge, ha.
It' s a bit crusty with oily residue but they all turn freely. I don't mind that on the outside of a bike.
My worry now is why I no longer have spark from my coils, maybe with bolting back my sprocket/chain guard plate some wires came out of their connectors, I'll try to check asap.
Turning the engine without plugs will not produce any visible results. It's simply to clear excess fuel from the chamber if you are having a hard time starting so as not to flood with fuel.
Have you tested your coils? Take a voltmeter set to 200 ohms and go between the wires, you should get a reading between 3-5. Then change voltmeter to 20k and read between either wire and the spark plug lead. You should read between 10-15k.
Edit: for the second test, you may have to go from plug wire to plug wire in order to get a correct reading.
@adventurco will check and let you know asap, have a few busy days ahead so might take a little while, tx for advice !
Hey guys,
After diagnosing I owe it to you guys to let you know what the problem was.
I checked all electrics, fuses, connectors, wires etc, anything that could be problematic in regards to an electrical problem. Everything was good.
What the actual problem was is as follows: in trying to get a test ride after changing my battery and plugs I rolled my bike out of the garage and my left hand controls (where my dead man's swith is) must have moved slightly, probably by me gripping the bars, and the dead man's switch got caught underneath the banjo bolt of the clutch lever.
That was the reason I had no spark and no electricity on my points.
It fired right up after fixing the position of my left hand controls and unsnagging the dead man's switch.
I wanted to bang my head against the wall, sometimes you don't look for the most obvious things. Anyway, thanks for the help.
I test drove and already hit some other issues, so I might ask some more stupid questions after I overdiagnose.
Cheers !
