Mr-Wolf
I need to get this stuff gone, make an offer! Worst that can happen is we finagle a bit. Plus order multiple things and I'll knock some cost off!
I have several parts from my 1979 cb650. That I do not need as badly as I need the money to finish the rebuild...
With that being said, I haven't really spent much time researching prices so if you feel something is under priced or over priced shoot me a message please.
All parts were in a box when I got the bike as a basket case, I just bought all new everything because I wanted to completely rebuild it. So I do not know anything about them.
I am located in central California.
Chain Guard - 20 +shp
Side covers - 30ea +shp
Front turn signals (working) - 20 +shp
Headlight (obviously broken, but figured the hardware could be salvaged?) - 10 +shp
Handlebars - 30ea +shp
Push/Pull cables (one cable is fraying, most shops can repair and replace ) - 5 +shp
Pilot lights (turns and high beam lights work for sure, not sure about the others, bottom two screw holes are broken as seen in picture) - 20 +shp
left controls - 20 +shp
Right controls - 25 +shp
Fuse block (All good) - 20 +shp
Reg/Rec (no clue how to test) - 50 +shp
Wiring harness (some wires are cut and some plastics are broken, but still a good base to use) - 10 +shp
Headlight mount - 25 +shp
Front and Rear Wheels (powder coated with reciept, Brand new wheel bearings never ridden on. Tires not included) - 150 +shp
Pistons and rings (Pistons are in great shape with no damage or rough spots what so ever. Rings are brand new, I opened the package and put them on the pistons but never slid the jugs on...so brand new. wrist pins are in great shape with no wear) - 80$ shp
Ignition switch without the plug - 5 +shp
Push button kill switch - $10 +shp
Handle bar controls - $10 +shp
Push pull half turn throttle assembly - $15 +shp
