1980 CM400T Toggle Switch Ignition
specialk21217
So I'm sure this or something similar has been answered but I have an 80 CM400T and the ignition broke. Tried ordering a new one and it is discontinued. Ordered one online and it was junk when I got it. I decided I want to wire in a toggle switch in its place. I can do the work just figuring out the correct way to wire it is the problem. Anyone know the proper style switch and how the wires need to go...I am also removing the light cluster tach and speedo so the wires for the lights on those aren't a concern unless I need them connected to run other things on the bike.
You're going to need a five pin automotive relay as well as a toggle to make it work on your bike.
Also, make sure your toggle can handle the current. 10A should work, but 15A would be even better.
For the toggle switch, red wire on one pole and the black, brown, and brown/white wires on the other. Additionally, you'll need a new wire to run from the black wire in the harness to pin 85 of the relay. Pin 86 and pin 30 of the relay go to the green wire from the ignition switch. Pin 87a goes to the black/white wire from the ignition switch and pin 87 from the relay is not used.
400 is CDI, you only need to connect trigger wire to ground.
Check wires coming out of generator, (behind left side cover, clipped into place in front of reg/rect IIRC?)
3 yellow are charging, light green /red trace neutral, the other two are for ignition (high speed and low speed trigger wires)
The low speed wire needs grounding to kill motor (bike has to be towed to about 20+mph for high speed winding to work)
This worked for the ignition but I do not have brake or running tail light. I checked the fuse and everything was fine am I missing something else?
The brown and brown/white wires from the old ignition switch also need to be connected to the opposite pole of the red wire on your new toggle switch.
I have all those on there. The tail light on there is an LED light if that changes anything.
Sonreir said:
Shouldn't matter. Check to see if you have voltage at the tail light wire (brown)?
I'll check if it's getting power at the light. The brake lights don't even work so I'm thinking the LED circuit its blown on the light itself
Tested and it is getting power to the light. So I'm guessing the light is bad. Ordered a new one today off amazon
