1981 XS400, first build.
Hey all, just getting started on the XS400 I picked up for a song. I'll save you all an excess of words and skip right to the photographic progress.
Beginnings:
Torn down:
Picked up these new forks for an absurd price given the condition and a recent rebuild:
Got the frame hoop welded up today with the help of my good friend Dan. Came out better than I could have hoped for. I'm quite happy with the results. I also cut the cross support and cinched in the frame by about an inch. The narrower profile really does it well.
Updates to come as I progress. I'll be starting into an engine rebuild soon, as at probably has some 35k on it and god knows how much nonsense to get sorted.
Great start! However you need to put something back in between the shockmounts. The frame will ride like chewinggum now and WILL BREAK, due to high stress points created by removing that brace.
Its ok to dive in both feet, but a friend who can weld is not an engineer at the same time ;)
Yes, it will give problems with tire clearance if you do a straigt tube, but if it was easy, everybody would do it ;)
^ What he said, plus you'll need something to mount the seat pan to anyway so a brace that doubles as a seat mount would be a good idea. I've got an XS750 which is at pretty much the same stage as yours.
a straight tube across just ahead of the shock mounts will be fine
be sure and check the tire up position at full travel of your shocks
leave some clearance from there to seat pan and cross tube
it is amazing how many builders overlook this important detail :o i would say 95% are clueless to where the tire ends up at full bump OR they just don't care
Thanks guys, I should have mentioned, I'm adding new support beams next shop day, just didn't have the time on Saturday. We had to cut the old one out to narrow the rear. Some flat bar is going back in between the suspension mounts, plus another bar a few inches behind the tank mount to add more support and provide mounting points for the seat pan and an eventual electronics box.
GOOD
remember the wheel travels up higher than the frame tubes check it fully bottomed springs off the shocks
Indeed, thought about that. I think I'm just going to put the rear most support in the same location the stock support was before we cut it out and narrowed the frame. Between that and the fact that I'll be using longer rear suspension than stock, I think clearance issues should be pretty well covered.
Also, anyone here used aircraft stripper and a powerwash to strip a frame? I'm thinking of trying it as a cheaper alternative to having it sandblasted.
yeah go ahead and build it without verifying suspension travel with your new shocks ,see how that works out for you ::)
i like what you did with the rear frame so far looks great
No need to get snippy. I'm simply stating that considering the new support is going where there already was one, and the new suspension is going to be longer AND have a stiffer spring rate than stock, there's no real reason there would be any clearance issues. Unless I'm missing something, it seems like relatively simple logic.
you are missing setting up proper suspension
stiffer than stock is not good unless you are fat
for the suspension to be set up correctly requires figuring out the correct spring rate and your suspension on occasion will reach full travel if set up correctly
all i am saying is if you don't figure exactly where the rear wheel is placed upon full compression of the shocks and build your seat and frame pieces to have a bit of clearance then you are doing it wrong
i am trying to help think ahead do the job right
I don't feel much like getting into the semantics, suffice to say that I certainly understand the merit of what you're saying on principle and I'll be sure to keep it in mind.
He can be a little coarse, but his hearts in the right place (I think)...
He's just saying, longer shocks can mean longer travel too. Just because a shock is longer doesn't mean it won't be just as short when fully compressed. You're probably okay, but it's easy to check
Started in on the engine a bit today. Pleasantly surprised to find everything much less of a shitshow than I expected, given the miles and the amount of grime that was on it when I got started.
