xb33bsa said:get it running![]()
see what you think, It doesn't sound like you will be riding enough to empty a tank each time out
bonus of mixing is you can burn some sweet smelling maxima 927![]()
VonYinzer said:You cant do a proper plug chop unless the engine is under load (actually functioning on the street).
Also... I want to state that I'm not trying to give you a hard time here if it seems that way. Just trying to get you to see that there is a right way and an "it'll work" way. The latter will often times cause more harm than good. You have a cool little bike. Would hate to see ya bust it up because ya skimped on the easy shit.
Are the bearings lubricated from the oil pump? Sounds iffy.deputy865 said:Got lucky. The K100 guru's said I'd be fine to run premix.
I just need to block off any existing oil pump stuff... Though it would be neat to have some sort of creative can attached to the bike. Maybe the NEXT one I decide to build, I'll go that route
Shane
noScooter trash said:Are the bearings lubricated from the oil pump? Sounds iffy.
