77SuzukiTS250
Active Member
Any forks recommended i like bulkier looking forks
Thanks
-Jarron-
Thanks
-Jarron-
mark13018 said:For what bike? Honda's cb450-cb750 all use 35mm.. Honda's are plentiful also, you could always do a bearing conversion with the all balls tapered bearings, if you're not talking about a Honda. They make sets to convert almost any two combinations.
SONICJK said:I would assume he's talking about a 77SuzukiTS250![]()
Scruffy said:35s are kind of spindly... these are 35s on a 1963 Honda 250 Scrambler. They desperately need 40W motor oil or similar to control the mushy feel... even with an SLS front drum.
Traditional forks are traditional forks. If you find a set with steel lowers, get them, if not the common as bellybutton lint aluminum versions work fine... just too common.
Scruffy said:Correct. I never said they were the same. But since I'm within 13 pounds of weighing the bike's displacement, those tiny little toy forks are pretty mushy...
Spindly is the look. I like the steel sliders because they are smaller diameter compared to the alloy ones. On a bike from the 60s, it isn't going to make any difference, slow is slow, and a 248cc p-twin is slow.
