6mm oil filter bolt was missing.....
Big R
Heaven is so far away.
As some of you may know, we received some free bikes from a local guy, one of which was an SL175. Recently I opened up the oil filter cover and looked for the 6mm phillips head bolt that holds the cap onto the filter .....but it wasn't there! So my question is 1) will that cap spinning freely on the filter do any real damage and 2) that bolt couldn't have found its way into the motor, could it?
There was no unusual sounds coming from the motor and no shavings in the oil or in the filter. But I would just like some confirmation. Thanks!
Are you sure there should be a 6mm bolt in there?
Doesn't the cover have a big circlip holding it on?
Usually, the bolt hole is to remove cover for cleaning centrifugal filter.
I really can;t remember as I haven't done a 175 since 1977
Yes, the 6mm bolt holds the cap down. They use an 8mm bolt to push the cap off (two different thread diameters in line). My 68 sloper had the same oil filter setup.
I think the 350's use the circlip, but I'm not sure. PJ, you should get a small bike! The fun per cc ratio goes up!
I remember now, was pretty tired last night.
It's 25mm long Phillips head screw.
It cant fall out when clutch cover is on
so its probably been removed some time ago.
If it was loose in there you would be able to see marks from it rattling around.
In all probability, someone removed it, couldn't get cover off and forgot to put it back.
BTW, 360 IS a small bike ;)
The owner was lucky. If the screw comes loose and presses against the spring loaded part in the outer cover, you lose oil pressure and all the top end of the motor turns a pretty shade of blue. Ask me how I know.......
If the filter cover was still in place, he probably dodged that bullet.
