71 Bonneville t120r
nodoze
Here i have a 71 bonneville 650, or reffered to as a t120R . The back story on it is , my grandpa was a triumph fanatic.... Every two or three years he bought a new one and kept the old one for about a decade he did this in the seventies along with collecting various triumph parts and frames along the way.
So when he got put in a nursing home several years ago he decided to give his completed bikes to family. My dad received a 73 trident, my youngest uncle a custom triumph chopper, and oldest uncle a 74 bonneville 750. And me a 71 650, im the only grand kid with a motorcycle enthusiasim so he thought it fitting.
When i got the bike it had 12k on it , was in good shape for sitting for 20+ years without being moved and i had it running in a weekend and idlign decent.
Well i decided it left alot to be wanted in a bike and the only way to get it clean like i wanted was ....... complete resto ......
heres how it sat for almost two years , just a powdercoated frame and tore down on my bench.
then this spring i really started to get busy with it . most of the parts are all original and while the resto is not 100% perfect it is done nicely .
heres some of some mock up and progress.
getting pretty much all closed up , didnt start this thread durign the begining of my build so im playing catch up with pics for you guys . not many parts left on the bench :)
and the piece de resistance! short crappy vid of a first start up, had some throttle cable issues which are now solved and need to re do my kick start (didnt know you were supposed to wind it once before install ) :-\
http://youtu.be/VonTiF_eN5Y
no body has chimed in on this yet but i have a question, on the oil cooler their are studs that hold it on, now i think one of the nuts / studs are stripped is their any way to replace this / replacment part i cna get ? its causing a small oil leak.
Turns out the nuts are the culprit not the "studs" which are part of the rocker shaft , threads on the shaft are great but the nuts not so much . So a new pair along with sealing Washers are on their way .
Sent from my HTC Hero S using Tapatalk 2
nice resto, sweet sounding bonnie....just that heat wrap going all the way back kinda uglies it up a bit IMO....cant beat that sound though ...im starting a 73 500 tiger next week, enjoy your bike!!!
I kinda dig the heat wrap , I could not Get the pipes to clean up and look presentable . Part of the image with the bike is to honor my grandpa thats why some of the items have been left on just the way he had em
i kinda figured thats why you put the heatwrap that far, nuthing wrong with honoring your grandfather, sounds like a great man..who knew great bikes, kudos for keeping it in the family.
Hopefully here in the next few weeks my dad is going to bring his trident , over for me to get running
Have a question for some of you guys , we had the bike running on the second kick without a battery a few weeks ago , went to start it last Friday , would not start had no spark etc , but I hook up a battery , started easy , unlocked battery Nd stayed running , is this normal ? I have a good new battery on order from the amazon sale
Nice bike man, sweet sound,
I know some Triumphs had a postion on the ignition key that allowed you to to start it up if you found your self out and about with a flat battery !!!! your manual will tell you if yours dose
I will have to check the manual out , thanks for the tip and compliment
Got the tank painted for the final touch , don't know if you can tell the difference or not
