71 CL350 fork question
CThor
I just bought a '71 CL350 and I would like to change out the front forks for the sealed type on the later models. Is it as simple as getting a whole setup from a later model CL or CB and swap them out? I'd like to keep the front drum brake though so are the CB forks different then? I think the main thing would be if the steering head bearings are the same size or not. If anyone has done this or can answer my question I'd appreciate it.
Thanks
Anyone? I've found a couple to buy if they will work, so just trying to make sure before i buy one.
You can't just swap the left and right forks with a later model. The tops are different. Yours has the ones that butt up to the bottom of the top tree without clamp bolts. You need a complete front end and axle from a 72-73 CL or a 72 CB to be compatible with your drum brake. The later front ends are wider and have a bolt clamp top tree where the fork tubes can be pushed up to lower the front of the bike.
Thanks for your answer. I was looking for the complete front end and think I found one.
