I got my cl350 running the other day. Just had to put gas in it and kick it over. Everything seemed to be running smoothly so I take it out for a short ride around a couple blocks. When I pull the clutch in to stop the bike just keeps revving up around 5-6k. I can see that the throttle isn't sticking, that was my first thought since it was hard to turn until I lubed it up after that initial ride. I have taken the carbs off today and have them soaking in lemon juice now. They were pretty clean though so I'm not sure that will fix the problem. When taking them apart I noticed that the floats weren't the same height on the carbs. Would that possibly cause the one cylinder to not get the fuel it needs while riding and lean out the motor possible and cause it to rev like that? That carb was on the right cylinder and I noticed the pressure coming out of that exhaust was slightly less than the left cylinder also. The bike would start up and idle fine, I revved it some while sitting there and it would always return to idle. It would only act up while riding when it was under load. Also does someone have a link or something to how to set the float heights for this year and model?
