72 CL350 Battery Options?!?
fluke12
Recently i came across motofiaccone's site and saw on his 360, he put 3 small batteries, instead of one large one http://motofiaccone.com/moto/39-cb360-cafe-racer/88-hiding-cafe-racer-batteries] [url]http://motofiaccone.com/moto/39-cb360-cafe-racer/88-hiding-cafe-racer-batteries[/url].
Has anyone had any experience with this? i was thinking of doing this for my 350 but i want to make sure i still have cold crank power to use the electric start. I don't have a ton of experience with the electric system, so any advice is appreciated.
Thanks!
If your using electric start, just get a small sealed battery,close to your stock ratings. That way u can mount it in its side in the tailsection.Went through the same thing.
Thanks for the reply. I was hoping to keep the stock tank and throw the battery in a small bump to fit the same line so it needs to be pretty small. I thought the pan motofiaccone made was a pretty slick solution.
Anyone have a good suggestion for battery size? Right now it's a typical 12v120ah battery and the manual says the starter motor needs 120a? I'm not great with the wiring so I'm looking for anything.
Thanks!
The easiest way to find out the minimum battery size is find a local bike or automotive shop where mechanic/tech has an 'amp clamp' ( and knows how to use it. ::))
Do an amp draw on battery ground cable (pull plug caps and fit spare grounded plugs so voltage has somewhere to go, if it starts you wont be able to get a amp draw reading)
You can do the same thing with a shunt or high amp meter, but, if you knew how you wouldn't be asking the question so I'm not bothering to give instructions
You'll probably have initial current around 70 amps and drop to 40 amps when motor is turning over
That will tell you how many CCA you need
Then, re-fit plug caps, start engine, check battery charging voltage and amperage.
Should drop after 1~2mins
Charging amps should be 1/10 of battery capacity but will be higher just after starting
voltage will be around 13.5~14.25.
If charging amps are higher, you need a conventional battery so you can top up electrolyte as it 'boils off'
A sealed battery will run at a higher pressure but when it dries out (and it will) it can either catch fire or explode
