cafepenguin
Active Member
Hello there
I have a 73' CB500 that currently is having a charging issue. I recently did an oil change and to let the motor warm up, I let the bike idle for a bit, while I cleaned up around the bike. Once warm enough, I turned off the engine, I drained the oil, then cranked the kick starter (with ignition off of course) to get the some of the oil that was up there out.
Replaced the oil.
Then when I went to restart it, the push button would not do it, I had to kick start it, which I was able to do. I rode it for a while, hoping that it would recharge the battery, but alas, the next time I went to start it, I had to kick start again. Once again, I rode for a bit, hoping to charge it. But again it did not.
So it appears to me that the battery is not charging even after riding for a bit. Any thoughts on where I should start checking would be much appreciated.
Thanks
Replaced the oil.
Thanks
