74 CB360 Cafe Racer -- 60 miles since build completion, $2250 obo
mxseven
1974 Honda CB360 Cafe Racer
First of all, I gotta give a shout out to chrisf of motofiaccone for the inspiration and endless help he gave while I was building this bike! Youdaman, Chris!
I bought this bike about 18 months ago in it's original unmodified condition.
I have since spent countless hours and $$$ rebuilding,
restoring, fabricating, and converting to Cafe Racer.
This bike has about 60 miles on it since completion. This bike
was torn down to the bare frame, chopped, gusseted, primed and
painted. Every mechanical part was disassembled except for the
bottom end of the engine, and the gearbox.
I bought this bike in Ohio without a title, and went through the
painstaking ordeal of tracking down the 2 previous owners, keeping all receipts, notarizing multiple
required documents, and making several trips to the DMV to
acquire the clean rebuilt title, which I have in hand. It has
been inspected, and is registered for the street and has a new KY
license plate.
I'll try to list everything new and/or replaced on this bike,
but I'm sure to forget a few things. It's really too much to
list.
-brand new tires and tubes, front and rear
-wheels have been cleaned, primed, and painted
-front brake rotor cross-drilled
-replaced original brake master cyl. and lever with one from a
GSXR-750
-new grips and all new cables
-Hella projection low beam and Hella high beam headlights on
custom stainless bracket
-Digital ICEMAN bargraph tach display, originally for use on
racing karts and formula cars. Able to display tons of
information and accept any kind of temp and pressure sensor
-new clubman handlebar
-new Honda key switch with two keys
-custom formed tank from a CL175, coated with Kreem sealer
-custom made vinyl seat
-new turn signals, flasher unit and taillights
-new rear view mirror
-rebuilt forks and triple tree bearings
-new o-ring chain
-new dunstall style mufflers
-custom fabricated stainless rearsets and relocated shifter/rear
brake levers
-completely rebuilt both carbs
-new cone air filters
-new fuel petcock
-replaced rubber intake manifolds with good used units
-new horn
-new battery
-new wheel bearings
-new points and spark plugs
-new NGK plug wire caps
-removed electric starter, kick start only. Starts on the first
or second kick every time.
-new engine gaskets including lower cyl gasket, head gasket,
clutch cover gasket, stator cover gasket, exhaust gaskets, cam
cover gasket, etc.
-valve clearance adjusted, ign. timing set
The only issue I have with this bike is the carbs need to be
sync'ed. I'm more of a fuel injection guy, so I'm not
experienced with carbs. Cylinders show good, even compression.
The bike runs just fine to ride, and I have ridden to work several times without issue.
It just needs an experienced hand to tune it.
One other thing I might do if this doesn't sell before the
winter is to rewire the lighting. The 35 year old connectors
tend to work themselves loose sometimes. There's not much
wiring to speak of, so it could probably be done in an
afternoon.
I can provide all receipts and I'll throw in the Clymer repair
manual and wiring diagrams as well.
This has been a really fun bike to build and ride, but I'm
looking to get into dual sporting/adventure riding, so I might
consider trading for a DRZ400 or similar.
My asking price is $2250 obo. I have spent lot more than that
in parts, and don't get me started on the amount of hours!!! :)
Feel free to call or email Mark @ 859-552-8617 or 7mrivera@gmail.com with any questions and more pics. Thanks for
looking!
