'74 CB360 Dual coil question
Sonreir said:
Use XT600 coils. They mount up without any changes and they're very cheap.
Are these the ones you are talking about?
https://sesmallengineparts.com/products/ignition-coil-for-yamaha-xt600-xt600e-1992-1994-1995-motorcycle?gclid=EAIaIQobChMIks-dvduK3QIVCtbACh1wUwBvEAQYCSABEgLFxPD_BwE
They don't work. I've tried it. XT coils use the wrong current because it's a CDI bike.
Maybe I'm thinking the XT500... there was a points version of the XT that should be nearly plug and play.
I did wonder if that was the case, and the xt500 is points based.
But the coils seem to be single LT connection, so i’m unsure how to wire those?
Eg
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F153014523953
Steve
Looking at the diagram, it looks like it might be magneto based. Probably best to skip the XT coils.
At that price, you won't lose much if you try them. Those look very like the coils that many sites around the world are selling for around 30 bucks a pop. I have no idea how to measure impedance, but if resistance values are say 5ohm primary and say 8-15k secondary, i'd go ahead and use them.
The CDI coils I am familiar with have a single low tension lead to the CDI and I think that all points/electronic ignition coils are 2 wire. I haven't seen any CDI twin LT coils but they are probably out there. Motoplat and PVL are exceptions in that the coil includes the CDI circuit so they have two leads - one is charge and the other is timing pulse.
Well sh1t, I'm no where's near needing coils, gotta get some pistons and have the jugs bored to them first.
Just trying to stow info for when I get to those bridges.
The difference is in what type of current they run off of. Some run off DC and some off AC. They aren't interchangeable. A bike with a magneto, like most dirt bikes of the era, use AC coils. The XT coils are AC. Our street Hondas use DC coils that run off rectified DC power.
Do we know for sure that the coils shown are actually AC type coils? Just because the seller lists an application doesn't always mean he's right.
I don't have a 94 XT600 so I looked on line at wiring diagrams and it looks like it runs a 12v DC ignition system. Anyone know for sure?
http://nocduk1.tripod.com/imagelib/sitebuilder/misc/show_image.html?linkedwidth=actual&linkpath=http://nocduk1.tripod.com/sitebuildercontent/sitebuilderpictures/xt600e_90_95_grafik_3tb.gif&target=tlx_new
You may have missed the post, but I have bought those same coils and discovered they are AC and don't work. That's how I learned all this- through my own fuckups. I have several coils I bought for my last 360 that don't work, and ended up rebuilding the stock coils. I imagine it's completely possible that the manufacturer uses the same molds and makes AC and DC coils that are identical, but the coils I bought that look identical to those coils that were for an XT do not work.
That is entirely possible that they use the same molding. The set of coils I bought from Europe look identical to those and they run fine with a DC system. Maybe Sonrier can shed some light on this conundrum.
What about this one: https://sesmallengineparts.com/collections/motorcycle-parts/products/ignition-coil-for-suzuki-intruder-volusia-800-vl800-2001-2004
New points and condensers arrived in the post yesterday, so this afternoon i built up a new points ‘loom’ and rebuilt. For the loom i used ‘high temp’ 200c rated wiring, double insulated and new crimped and soldered bullet connections.
The new points dont bloody fit !!!
They bolt up to the plate ok but the ‘cams’ are too large and there isnt enough adjustment to get the required points gaps. The points were advertised with pics of japanese made items with black moving parts, but cheapo no marking parts arrived with brown parts and these didnt fit. So watch out for those.
I built the bike back up with the old points and had a test, with new lt and ht wiring and condensers, ran well in the garage but not been out yet.
I’m still awaiting two new NGK Spark plug connectors to finish the job.
Steve
WOW !
New NGK plug caps arrived so i installed those, checked the timing again, and pressed the starter.
Bike fired up immediately, never did that before !
So, somewhere in the replacement of the old HT and LT wiring, new condensers, new plug caps an old weakness was erradicated.
Took the bike for a good test run today and it performed fantastically, pulls strongly and revs really freely.
Stopped for a coffee and a chat, on the way home it’s not running so well, then dies at a junction, wont restart..... until i turn the fuel tap to reserve and all is well again.
Was having so much fun i ran out of fuel !
Need to find a next job to do, maybe swing arm bushes as havent touched those.
Steve
