'74 CB360 Project
menopause_man
Started this project a few months ago.
Likely going to exchange the boots.
Nothing impressive thus far; just wanted to document this to keep some motivation.
Judging by how successful this thread was originally, thought it was necessary to post an update.
Welded the hoop on this morning
Gas tank finally filled in, not looking too bad.
Debating whether to have the pipes painted in flat black (powercoat) or just wrap them.
This seems like a dumb question, but, before wiring it all up, I am trying to achieve clean flat grinds on the engine fins. As of late the paint has been scrapping off, looking very scraggly. I assume the ground/flat fin look comes on some engines stock. Is there a way (and a tool) to get a nice thick and even grind on those edges to really increase the contrast?
for the silver edges on your fins, prep it and paint it, then use a sanding block with 800 grit paper flat on the edges.
A good start so far. My suggestion is not to go overboard. Money can be spent pretty fast, then there's the extra time it takes to get every detail perfect. Just get it done and ride the snot out of it.
Thanks for the suggestion on the fins. I'll give it a shot next week.
Very easy to go overboard. Trying to hold back a bit on worrying about the details.
Making progress. Seat is about finished.
Initial fiberglass. Good position, but with foam added it wouldn't allow enough room to comfortably sit.
Did some cutting and pasting.
Shaped the foam. Ready for upholstery and paint.
