'75 CB200 electronic ignition + Dyna mini coil - Help!
the CB200 is a 360 degree twin and that means both pistons rise and fall together. So that means you use a single coil with two HT (spark plug) leads.
Remember that Dyna mini coils are not suited to points ignition. If you use points or a dyna S ignition, use normal large Dyna coils.
I play on doing tnahvu's exact set up. I wish i could know exactly how this setup ended up working for him? He also stated that he used dc1-2. I found a great price on a dc1-3. Same 3.0ohm. Would that matter? Whats the difference in the two coils? Thanks for the reply teazer. I'm new to motorcycles and figured a cb200t would be a great starting place to learn. I have worked on and owned several old cars 60's-70's and up. So i am a little mechanical savvy. My bike will wouldn't start so i went through the manual and set everything back to factory (lifters, timing, carbs) It started for a bit then just stopped. Started backfiring and now wont even start.... I'm i going in the right direction with switching to a electronic ignition set up?
I don't like to throw cash at problems but I figure that an electronic ignition is an investment I should probably make anyway.
I would focus on cleaning the carbs meticulously next. Clean out every jet and drilling but try to avoid poking wire in the holes.
