76 cb550 $250 find!
Ryan66 said:
Bike is def gonna nickle and dime with all the little stuff it needs to be rideable. Not to mention all the cafe parts i want to put on it
yeah i hear you. we can def help you out no problem. i bought my bike for $200 but I ended up putting 1700 into her so far. But then again I did go for the expensive shit like chrome plating and stuff.
If your going try to conserve money as much as possible one pointer I would give is not to sacrifice the essentials. Brake seal kits and motor top end stuff can be pricey at times, but some stuff you don't want to go cheap on. Then if your going to tear down the hole bike and redo it I would suggest powder coating the frame for durability. It can be painted but don't use cheap retail stuff. It will only chip. Good luck.
Oh and get the bike running first, then mach-up, tear down, paint, powder, etc, then put her back together.
Yep im in the process of getting it tore down. Carbs will be soaking this weekend. Got all the electrical sorted out last weekend. Need to bleed the front brake. Then i bleieve it'll be road worthy. Has a brand new rear tire. I need intake boots that go from the airbox also. But i also may buy a forum members airbox and velocity stack combo he makes. Pods are almost $200 anyways this kit is 279 and should be easier to jet then pods. Once its running im gonna order clubmans, im making my seat and then ill fab up some rearsets. Then come winter i'll strip it down pc the frame, wheels, and polish the motor then focus on the little stuff
See if your local dealer can order a set of stock rubber intakes that fit inside the air box. They are a velocity stack shape and work very well. Then fabricate a replacement air box to take any off the shelf modern filter. It would take a little time and you need to get someone to weld it up, but it would be cheaper and more effective than pods. I'm not familiar with the other airbox that you mentioned at $279. Do you have a link?
So inspecting my carbs my number 1 carb the slide doesnt move. The arm that pulls the slide barely moves. any ideas on that? i pull on the throttle wheel and the slides go halfway up. Arent the slides supposed to go all the way up?
Soak em in penetrating oil, then boil them in lemon juice, then see what you've got.
Length of travel depends on the carb, some do go "all the way up" while other don't.
Pics/videos help us diagnose a lot. words can sometimes confuse things!
i see the two 7mm nuts on top. i took one out to free the slide up. im assuming by taking both out the slide comes out? but i dont see how with that arm in there. I got it unstuck. But now the number 1 slide sits a little higher then the rest. If i push down on i think its the big 12mm with the spring inside it pushes the slide down where it should be. The other three i cant push down like that. So now they all travel all the way to the top.
See the difference?
The yellow adjusters control the synchronization between the 4 carbs. (this is what allows you to adjust each carb for it's cylinder but still have all 4 work in unison)
As a general rule the synch shouldn't need to be set all that often, about as often as you adjust your valve clearances.
Significant engine work will require re-synching, but in general daily riding shouldn't.
Ya i was told to loosen the nut and the flat head screw adjusts slide height. Arent those what you turn also when doing a carb sync while its running?
yes, best way to adjust carbs is to get your timing right first, the bike warmed up. 5 mins ride. Then hook up synchronizer tool. There is a specific order in which you should adjust them so they all match. I am not sure what it is but i think ive seen some videos on the internet.
Have you confirmed the compression of the motor?
I would start there. Maybe the carbs were tuned to compensate for something.........
Manual will have a good write up on tuning
No i have not but i will once the carbs go back on. Just like any other compression check right? hold throttle open and turn over till gauge stops moving?
dont just change the sync settings on the carbs now.
clean the passages and such but leave those seatings alone.
The yellow paint should be from the fatory....not something to start messing with without knowing more about the motor.
Carbs dont need to be on for the compression test.
you are looking more for even numbers then the actual numbers.
IF one or more are different then move on to a leak down to know if its the valves or the rings.
Think of things as a system and take it one step at a time.
download the FACTORY manual cymer one is eh at best
Get the motor running 100% as it left the factory first before you start adding mods and variables.
Well you dont think it had to do something with the stuck slide? And i would think the carbs all being the same would be the factory setting. Like i said in the second pic where my finger is i can push that nut down the bigger one and itll push the slide down. The other three dont move if i push on them
Did a little more work on it. Chopped and painted the front fender. Ordered some carb rebuild kits. Ordered some blinkers from dime city. Starting to come around. Probably order some clubmans next with grips.
Some updates on here. Ordered some very nice blinkers front and rear from dime city. Awaiting patiently for them. Upon taking the headlight off it seems somebody was into the wiring at least on the blinkers. So now ith new blinkers ill run new wires as well. Gonna cut down the rear fender as well this week. Carbs are awaiting my rebuild, got the kits just been lazy lol. I need the right side control switches and wires if anyone knows of any. Then ill check the timing, oil and filter change and hopefully start it up. Then its tank dents, clubmans, and a seat fab
Got my clubmans and some other small bits. Finishing the wiring up also. Be scotch briting the rims and painting them black this weekend. Hopefully they turn out ok. Gonna prep and paint them right so we'll see. pics pending.
Ryan,
You are right that all 4 slides should open smoothly and evenly. If that left slide is partially stuck the linkage may have become damaged. I would pop the top covers off the carbs and see if the generous application of WD40 or brake cleaner frees it up. Pushing on the individual linkages should not move one slide - they should all move together.
teazer said:
Ryan,
I got them all good now. Soaked them in boiling lemon juice and water. Soaked them in pb blaster after. THen went and put rebuild kits in them. THat same carb that was sticking is missing the emulsion tube that the needle sits in. That, a timing check, valve lash check, and a battery is all that stops me from starting it. Oh and of course my wallet. So in the meantime im keeping myself busy and doing the cheap stuff to it
