82 CB450T will not start - at all
crazy_eights
Don't ride faster than your angel can fly
Hello everyone,
I am in desperate need of some assistance. I finished my project, 1982 CB450 hawk and it was running like a dream, changed airbox to pods, new muffler off a CB750, new jets, carbs all clean and sparkling. I put maybe 300 kms on it since i stopped making modifications on it and was happy with the result.
Coming back from work it was raining a bit, but not enough to cause any trouble, before i left i turned the idle knob up a bit to give me a quicker warm up and not have any issues stalling while in traffic. So it was idling at 2500 instead of 1500. Still running well. I got home, turned it off and it never started up again after that. I press the start button and nothing, not even a click, no sound at all. Won't turn over, but i have power, the light are on, signals work, i checked the battery and it has power, 12.8V, i took off the starter and hooked it up to the battery and it spun like crazy, so it's not that. Fuses were good.... i have no idea what else i could look at and test. CDI unit? maybe? or Ignition Coil? I doubt that because i can start it with a PUSH start down the driveway and it runs, but it won't start on it's own.
Any help would be appreciated.
OK... so you can push start it and it will work, but when you use the starter motor, the engine turns over but will not start?
If i use the starter motor it will not turn over, it will no do anything, ABSOLUTELY ANYTHING. There is no clicking sound from the starter relay, the engine doesn't move no matter how hard and fast i press that button. No spark, either. But it works with a push.
Take a wrench and arc it across the connectors (large studs with lock nuts) on the solenoid and report back.
Is this with battery hooked up? No battery? While attempting to start it? Or take the starter relay off the bike and do it like that?
Or should i try them all and see what happens? :) It can't get worse than not working, unless it burst into a big ball of fire.
On bike, battery hooked up, key switch turned to on. If it starts shorting across the terminals, the starter solenoid is bad or one of the leads from the push button (or the button itself) is bad. If the bike got drenched, it may be as simple as wet contacts in the push button. Take it apart and make sure it is not only dry, but clean, Clean any switch metal by scrubbing with a pencil eraser, the same as you do model railroad track or slot car track and car chassis contacts.
With the battery hooked up arc the connectors on the solenoid. What Sonreir is saying is it sounds like you have a bad starter solenoid and you're basically bypassing the solenoid when you do this and the engine should turn over, if it's just a bad solenoid.
A friend of mine had this happen to a "personal watercraft" recently.
Clean your starter-button contacts.
When you jump the solenoid, you're bypassing the starter button and also the actual solenoid switch.
So with the bypass, if it shorts out and i'm on the ground shaking uncontrollably, we can assume the relay is bad and needs changing. If nothing happens and/or the bike starts up i'll take apart the switch and maybe that will fix the problem.
i shall do as instructed and report my findings.
Thank you, i now have some hope to get me through the day.
Unless you lick your finger and use that to short the solenoid, you won't have anything to worry about besides a little spark show. Be careful not to touch the frame with your hands or tools while doing this, just as a precaution.
When you're shorting this solenoid switch, you're bypassing the starter button and the solenoid switch, which is inside the little solenoid canister.
If the bike turns over, then clean your button. If that does not do it, replace your solenoid.
If the bike does not turn over...well let's just wait for you to report back.
Unless you've covered your hands in iron filings, 12V won't be enough to overcome the resistance of your skin. That is, you can't shock yourself with 12V.
The purpose of shorting across the terminals is to see if the solenoid or starter button are the problem. Bridging the connection between those two wires is what happens when you press the starter button. If you short the connection and the engine starts turning over you know you have a bad starter relay or starter button. If nothing happens, it's likely the starter motor (or a connection to the starter motor).
http://www.youtube.com/watch?v=DYec1yFX3YI
This video gives a good visual of what is happening, i can't wait to check if the bypass is going to work.
That reminds me. If the engine does turn over, then you can tell right away if it's the solenoid switch or the starter button by grounding out the short lead that is not black. The black lead is the common power from the battery and must remain connected.
If you ground this short lead to a good conducting frame component and it turns, your solenoid switch is working.
Clean your button.
Thank you for all your help, the issue has been resolved. I put a screwdriver over the leads on the relay and then pushed the start button and it turned over, eliminating the start button as the problem and finding the starter relay was bad. i also tested it against the battery to check for the clicking sound, and nothing. So i do need a new relay.
Thank you again for the replies. ;D
