luke000
Hello, I am just working on my brand new used 83 CB550SC nighthawk. I got some of the electrical problems solved enough to get it to fire. But now it will idle and rev up with the choke but if I use the throttle at all the engine dies... I have spark and compression all across the board but cylinder 2 does not seem like it is firing and cylinder 3 seems weak. I am judging this by them not putting out the exhaust gas like cylinders 1&4 (the exhaust is off the bike). My mind tells me that the carbs are probably clogged or out of adjustment, is my thinking correct? Any others areas you guys would suggest I look enforce pulling the carbs off?
