Acewell wiring headache :(
Cafelel
So, I'm wanting to fit an Acewell 2853 but am stuck before I even start.
I've looked at the wiring diagram but that's no help :(
1. When wiring I'm assuming the feed to the high beam and indicators splice in after the switch but before clock on their diagram? But before or after relay? (Thinking before for high beam and after for indicators)
2. Assuming above is right then when I switch on my indicator would the power not also feed back through the wire from the hazard switch causing the hazard light to then flash?
My head is hurting :(
1.) Not sure what you mean about the relay? If you're referring to the flasher relay, then that comes before the switches, so the gauge indicator lights will all be after the switches.
2.) Probably, yes. You may need diodes to isolate the circuit, depending on how your hazard lights are wired up.
Wouldn't it be lovely if things were simple.....
Thanks.
Made harder as I'm also fitting the M Gadget unit into the mix :/
But as I've decided to make a brand new loom rather than using current one I guess I just take it one step at a time :)
