am i crazy? engine design.
m357.5 said:
Norton was very succesful with their rotary, 588, won the senior TT at the Isle of Mann back in 1992. The F1 was the road version and the sounds they produce are beyond wicked.
I remember seeing it racing at Donington Park in 1980.
Had too look at Revtech link, thought it was the Harley clone (not exactly innovative :D)
I've seen that before, had problems with weight of bearings/bearings exploding.
Their math is a bit off, 100 % of power losses add up to 100% of energy in fuel?
What drives the wheels then?
Having peak power transmission at 10~30 degrees ATD is good, could probably do same thing with less moving parts
(look at marine diesels)
Not sure how all the moving parts have lower friction and 50% efficiency though? (no matter what, only ~30% of energy in fuel is used, majority of energy is turned into heat and chemical byproducts)
X4v2, 2 valves per cyl, pushrod motor, anyone want to speculate why? ( I have a good idea, and it's not just to prototype)
It's really interesting ( I like messing with engines) but I don't think we are going to see t in production any time soon, probably going to be a while before it's a high speed engine
PJ
very very cool stuff...
came up with another engine design today... should make good power, but the only problem i have with it is that the piston design is essentially free to move at any rpm, without any direct connection to the camshafts. I have a solution but it makes the design a tad more complex then id like.
ill get some drawings done and post them up... the ones i have on loose-leaf are a bit messy :D
now THIS one is crazy. on further thinking, it will only work as a two stroke. current worries are blowing the piston through the head.
any questions, just ask.
Thats pretty cool, only problem I can see is the added complexity of another clutch setup, and any frictional losses associated with that. Other wise its pretty cleane except for the one-way gear setup - might be some problems there on the bypass phase unless the teeth are manufactured in a special way or the entire shaft has an offset position engaged movement in the oposite direction...
Cool - boingk
I'm not seeing it?
you mean to use something like a couple of bicycle free-wheels as one way clutches?
The forces involved are much higher than you imagine
You need more 'arrows' ;D
If 'crank' can 'spin free' what stops piston just hitting head and not returning?
BTW, try and get hold of 'Piston Aero Engines' by Bill Gunson, couple of oscillating designs
You may as well waste your time 'productively' and learn something. ;)
PJ
crazypj said:
I'm not seeing it?
PJ
spot on pj with the freewheel clutches... just MUCH stronger then the ones on a bike. :D
haha... yes, more arrows are indeed necessary.
the thing that stops the piston from hitting the head is the opposite side igniting and blowing it back... again, that is my flaw. ;)
In that case, you'll have some major issues trying to start it.
Keep drawing, something workable may appear
PJ
Probably never see it as a high RPM engine - it's design advantage is that you can control / vary piston speed with the shape of the "ramps". Which means you can transfer more of the combustion energy to the crank by slowing down the piston after ignition.....although I agree with you that the ramped crank setup can't be any more efficient than a conventional conrod set-up.
Anyway, in the spirit of this thread, it's innovative at least ;)
will do...
i have to grab a copy of that book also.
