At my wits end with cb550 clutch
I know this is going to sound odd, but do you have the right number of plates and with the 4 bolts lightly tightened, are the plates clamped together? It looks like they may not be clamped adequately but that could just be an optical illusion.
With the bolts tight, put the bike in gear and turn the rear wheel with the side cover off and see if the clutch outer and inner turn together or does the inner turn and the outer stay still? If so, the plates are not clamped together they way they should be.
BTW the 4 bolts do not need to be very tight. I believe that they just bottom out and that's it. Don't try to tighten them too much. The manual will have a torque setting and you may be surprised how low it is. It's a one finger job.
you can only believe what YOU see
hence the rule
measure twice tear your hair out once
i have even been supplied a clutch with the wrong pressure plate and the fingers were to long
that took a while to figure out
Ok, so I'm back at it. After thinking about it all night I'm hoping that possibly my dig caliper is off. The reason I'm thinking this is first it's a wonderful harbor freight purchase. And two that I know the used plates I have ran well and are measured out at the same width as the new ones I have on hand. I'm going to finish the install with the used ones. I've tightened the bolts flush with their mounts with not a lot of pressure just enough to get them flush. Just for the record my clymer's does not mention how tight to screw down the plate. In fact it skips right over plate installation and goes right into the transmission section. I found a reference on sohc to 6lb pressure but I think the confusion comes in when screwing four screws with four separate springs. Anyone of these springs can produce about 6lbs of pressure on they're own. That why I decide to just "flush" mount them. Also on my previous tries I did not go this tight so it's worth a try.
spring plate sits within the basket edge.
springs are compressed and I can see from the top angle that backing plate is tight against the fab n' metal plates. And I can see room behind the backing plate for it to move. Also with the back tire off the ground everthing seems to move together. One thing that bothers me is by pressing on the "dumbbell" I can not see any budge in the backing plate. I know my arm can not supply the sustained energy the metal lever on the cover can but still bothering me. If this does work this will be one tight clutch.
Just to cross the t's on this I measured the distance from the edge of the cover mount to the end of the "dumbbell". I'm not going to include the actual numbers because my caliper may be off. But from measuring the distance on the cover edge to where the "dumbbell" sits in the cover, it looks like this should work (crossing my fingers and the first time I've thought to measure that on a clutch install, might do it every time for now on).
backed out the adjuster screw on the cover. And given the cable slack. I attach the cable to the cover and then mount. It's just easier to adjust afterwards.
Gonna put the cover on and try her out. Wish me luck
Scanned the replies. Did you check all the disks on a flat surface to see if they are true? Would give you some trouble if not.
6-10 lbs is right for the clutch basket bolts. I go by 1 n-M which is roughly in that range. Anything higher can mar the threads and reduce the shear strength of the bolts.
Make sure you're zeroing out your caliper while its completely closed before you measure, that can easily skew your measurements.
Well guy's it worked! As soon as I got the cover back on I noticed the wheel was lock up in gear. For the first time during all this messing around. The dots on the clutch arm lined up by themselves. Had to add tension to the cable at the top adjuster to get response in the lever.
I did check the flatness of the plates when I initially cleaned them up. But it is something I should've double checked. As far as the caliper is concerned I think it's just a cheap tool. I may have to buy a nice one. Going to check it later on some wrench gaps.
I feel like I should mention a couple things for those looking for tips on how to do this. When applying the cover be aware of your gasket position at all times. Two of the bolt holes have "champhers" (don't know the proper name) to help the cover line up. I tap gently with a rubber mallet to get it in position. If having trouble with getting it on the kick spindle you can wd the spindle and rubber seal on the cover then place a 20mm socket over the spindle and cover and GENTLY tap. I place the same bolts in the same holes they came from. With some anti seize on them. Finger tighten them and then start final tightening them starting with the bottom ones. You're most likely going to get a leak from the bottom area if any so take care. Also I wore full gear when starting this thing up to test it. I'm playing with the gearing system and the chances of the bike flying out from under you are there. I also follow all of soneir's first start up rules. Even had the fire extinguisher next to me in the street. Do it everytime I start something that's been sitting or rebuilt.
Thank you everyone that commented and helped me think this through. She rips! Needs a few adjustments and some upholstery but I'm completely happy with her. I'll snap a few pics after I get the cowl back on and the sun is out. Thanks guys
Been lurking this thread since you started it, couldn't comment anything that was not already stated, so I sat back and waited to see how it turned out. I always enjoy when a problem gets solved with some help and encouragement from fellow DTT'rs ....one of the many reasons I enjoy this forum. Glad you got it figured out, and glad for those who came along side.
Yeah me too. Forgot what a good sounding board and resource it is. Going to make it a point to visit it a bit more. And maybe start a build tread on the next project now that this one is mostly in the bag.
Just for grinns... Didja loosen this: jam nut and screw, back it off until loose before the cover went on then adjust the screw in to just snug then tighten the jam? all of the cable adjustments are after this process.
