bandit upgrade
got the paint work 85% done... all the black has been shot, the tail fairings are shot and cleared, all the little odds and ends plastic deals are shot, reflective clear, and satin cleared....
only left on the paint work is to clear the front fairing side pannels, airbrush and clear the tank and small back section of the tail, and main windshield... then paint work is DONE!
with any luck the swingarm bearings will be there today and i can get the wheels back on this sucker and shorten the wires up a bit for the HID, hand warmers, and few other odds and ends... Saturday put back on the plastics and add fluids... and ride this sucker!
damn, you been drinking a buttload of coffee havent you hahahah
outstanding work as usual homie!
well... GOT ALOT DONE!!!! was able to finish the airbrush work on the tank, covers, front shield, and then also lay the clear down. from there rebuilt the Front and rear brakes, installed new brake pads, installed the valve cover, forks rebuilt and installed, front fender installed, and brakes put on as well as the fork brace. wired in switches into the plastics, installed GSXR rear shock and located the resivor, installed rear turn sigs.
Left to do: shorten wires up and clean them up, wire rear turn sigs, add plastics, install swing arm and bearings (they are still not here or i would be riding), add rear wheel. go over everything... then work on the rear floating fender on the rear tire
here are the pics:
Paint work:
(the pearl silver looks insane under the satin clear)
covers and caps on the bike
Mechanical stuff:
wheel assembled and bearings in
black contols tuck nicely behind the guards
red grill is on
new shock is in
have to make a bracket for the resivor
stock GSXR rear turn sigs, shortened and painted to match the plastics (i have to be seen)
what is left:
wiring wiring wiring... spent 4 or 5 hours with a soldering iron in my hands shortening and soldering wires to length. make it look nice and tight. LEDs are all wired and ready to go, eliminated the clutch switch, some more odds and ends, then got the front fairing mounted
on the grip warmers i removed the casing and made a box for the electronics under the back side of the fairing and ran the knob though the plastics for a cleaner look you can see the small LED light tapped in front of that as well
re did the wiring on the 2nd brake light
turn sigs all buttoned up
HID and control switches all cut and soldered to lenght
other pics
Hey, I just checked this tthread out for the first time. Cool bike, your gonna scarin kids with that paint job!!!!!!!!!! ;D
so... I PROMISE to get a real camera tomorrow... promise!
all I have left is to add fluids, install lower wind deflectors on the forks, 3m protective tape on the rear fairing, install saddle bags, make (coat and weld) rear floating fender (this will be done tomorrow some time), mount shock resivor
yesterday: got new swing arm bushings in, installed swing arm and dog bones, got rear wheel in place, mounted and installed fog lights, finished leds, installed rear fairings/grab rails, installed exhust (with copper seal), final mounted front fender, lubed and cleaned chain, installed tank, put back on the seat
i am glad that i left the exhaust chrome rather than coating it, i kind of like how it stands out... but i have another header so i may just coat it and toss it on to see how i like it... bike looks like it could be in a comic book, love it so far... the suspension feels great but i have not rode it yet, not you typcial fighter but it should handle 10x's better... carbs where synced and balanced before tear down, valves set, float needle adjusted, baffle removed, progressive suspension up front with 15w oil, rear GSXR shock with remote resivor, 170 rear tire, new pads, rebuilt brakes... bike should handle betterthan ever!
black swing arm was 100% the right call!
again i promise that i will get a real camera on this sucker to do it some justice! was pouring today and last night so i did not want to roll it out there
Man Joe,
What skill!!! 8) Great work. Wish I knew someone like you in my town. Can't wait to see the bike in some quality pictures
thanks for the heads up man... i had tech look at it this morning we should be good to go now...
took her for a rip this afternoon and snapped some pics!
switch controls on the dash
thanks guys! have to say it is a BLAST!!!
OK... well i will start out by saying WOW... what a blast to ride! the suspension upgrades are spot on!!! she was a bit slick at first with the new rear tire but now i have 120 miles on her she sticks like glue! seems to have more throttle response now that the valves are adjusted and the carbs are dialed in...
last night Tim and i got to work on the floating rear fender...
bent some round bar to act as a support, then moved on to the fender portion
first we did a mock up and then tacked it in
bracket done
made up and welded on a bung to conect to the chain guard to keep it from moving around
also cut and shaved/bent a support bracket to keep it from moving up and down
and mock up on the bike
Not completely done as of yet, still have to powder coat it, going to 2 tone this, do the bracket in red, and the lid in flat black... then have to drill and tap the swing arm to make the lower mount bolt up
also was out riding at night figured i would post up a night shot with LED's on
well can now say i am done with all i set out to do on the bandit! was able to finish up the floating rear fender this weekend, get the 2 tone powder on there... works awesome and is the only one of its kind!
Well she is back!!! replaced/fixed everything that was damaged due to getting hit on the highway this winter. I still have a bit of touch up to do on the fairing, as well as paint on the bags!
would blow your mind how much stuff i was able to load into them and bring to the shop... got pissed on yesterday while riding and inside the bags where dry as a bone!!!
just could not rock the red bags... could not do it! so pulled them off got them all prepped up... and laid some paint... then got some new buckles (the stock where really tired) coated them all red to match the rest of the powder work... also coated the support brackets for the bags... got it all back on and done
came back from a night of blasting country roads... snapped a few pics of it lit up
with the HID on and fog lights
