Bar Clearence
65Bellett
Hi Guys, I have dropped a pair of Ace Bars on my bike and they knock on the big capacity touring tank I have on the bike but I am not sure if it is going to bother me as I ride. The bike is in the middle of a rebuild so I can not test ride it. I am in the middle of sourcing a standard tank and I will be beating it to fit.
What I want to know is, is there a rule of thumb about how many degrees of front wheel movement is needed while riding?
up to the rider. once at speed... you really only use a couple of degrees (unless if your dirt track riding :D :D)
its a pain at slow speed to have it hit the tank. ever consider bar dents?
if not bar dents (fuckin ugly imo) you can weld a little blob on each of the steering stops, then file/grind till it just clears the tank.
thats another option, but the point of bar dents is to keep the same range as stock.
bar dents look good if done correctly.
Should have about 2" clearance between bar and tank.
Doesn't matter how you do it.
It's a safety issue, you fall down, bars turn, your caught between bar and tank, thumb get trapped, minus thumb :o ( It has happened which is why the numbers came about)
PJ
I am definitely going to be putting some bar dents into my modified stock tank. The mIn reason I ask about clearance is I have a big touring tank I use when doing some distance. It gives me a fair bit of turn. I think I am going to make up a steering lock to stop the bars going all the way back to the tank and jamming fingers.
