Bar end signal?
lhemrick
Active Member
I have removed the stock signals and installed a set of bar end signals on a 1970 cb350k. With only the one set of lights they won't flash unless you reconnect the rear ones (which I don't want). I admit that I'm not the smartest when it comes to electrical issues so how do I fix this?
Thanks!
You need a electronic turn signal relay. They sell them at most auto parts stores, but check out the ones made for LED lights at www.superbrightleds.com too.
You can also pick up some resistors at any auto parts store, used for installing LED lights. You just wire them in place of a signal.
You could......but resistors can get pretty hot with constant use. As in too hot to touch by hand. That's why I never recommend them.
Also they negate the benefits of the LEDs.
You can use an EP-34, available at Autozone, etc. You may have to run a ground if you aren't already using a three-prong flasher.
Got myself an EP34 electronic flasher today at Advance Auto and installed it. Worked like a charm! Thanks fellows for the help!
Lynn
OK it happened! Almost ready to make it look pretty!
