battery question (i searched...)
timdhawk
Im looking for the thinest battery that i can find meeting the 12v 14Ah minimum for a 78 cb750. I have scoured the web (okay 4-5 places) and and searched here and can only come up with batterises right at 3" in width.
Anybody have any links or know of any batteries that are smaller in width than 3" that can lay on its side?
any ideas or info would be appreciated! thanks
One of the smallest batteries I have found is from Braille Batteries: http://www.carbonfiberbattery.com/
Off the wall sugestion... stuff your handlebars/frame with rechargable C cell batteries :o
So crazy it just might work :D
Not crazy, it would work. you'd need 10 of 'em. you don't need anywhere near 14ah for your bike. my bike came with a 14ah and I'm running a 4.5ah with no problems. it even works the electric start when fully charged. If you have a decent charging system you can get away with a very small battery. just go find a small SLA battery like for a computer ups or emergency lighting system you can tip these on their sides no problem. I've actually seen an electric scooter powered by NiMh 'D' cells in the fork tubes. if you go that way just make sure you use NiMh not NiCad or Lithium Ion cells.
it's not really worth starting a new topic, but i've got a sealed lead acid battery that has flat tab type terminals rather then metal post type ones. whats the best/neatest way of connecting them to the existing bike wiring? is there some kind of connector that clips on,?
;D
cheers,
i thought i would need heavy gauge wire as well, your's appears much thinner then i would have guessed, is there some kind of rule of thumb?
Yes, but I don't know it... I went with the classic "get a friend that knows more about electrics than me to tell me what to use"
At worst, use what you think might be too small and check often to see if it ever gets hot, if it ever get's real hot, go up a size. Carry extra wire with you at all times until you feel confident in it (then you'll be a practical expert).
You really only need the heavy wire for the starter, Loudbike is kick only so the other items won't draw the current to melt wires like electric starters do.
Cheers ;D
