CanadaDan said:Amp/HP/Torque ratings are what you want to look at... too many budget models will simply stop when enough preasure is applied... or they overload and trip the circuit breaker (done this many times with my buffing machine at work)
My best one is an old ~3400rpm Craftsman with only 1/3 hp... but at 6.2 amp I've yet to have a problem with it. The only issue is no electrc brake and GREAT bearings... it spins for a few minutes after I shut it off, I have to be really carefull working around it after grinding something![]()
i also found long hours of buffing cause a headache, from the aluminum dust, so lately i wear a respirator, goggles and hat, i'm buying coveralls, and gloves,but look at what i've done in a few days, with a $35 grinder,i'll need shades come this spring from the glare,Shooter said:Big diameter with powerful motor definitely required for buffing work. My small 6" grinder with wire wheel did a lot of hard work but sometimes it was hard to get an angle on a part due to small wheel diameter.
Wire fling from bench grinders is a major hazard - where safety glasses.
I also found buffing and grinding for many hours had a detrimental effect on the skin on my face and irritated my eyes. Hard to avoid so I tried to off set my head position as much as possible.
Possible solution I just thought about - a plexiglass shield on a flexible arm.
hey thanks, first i used a wire wheel to remove paint, then 400 grit sandpaper, then 600 grit, blk polishing compound, then red, now i gotta seal it, the surface is so fine that moving my finger over it will leave fine scratch marks,apparently now i have Alzheimer,HerrDeacon said:Wow, nice work. What kind of polish did you use?
