bike is bogging
haloskycrash
I have a 1975 CB 750F. I recently had this problem where every 1/4 of a mile the bike would run out of gas. I replaced the fuel filter and checked the line. Everything is flowing ok. Then I started it up and something sounded wrong. Felt the exhaust and the 2 right cylinders were not firing. Thhhen I replaced the spark plugs. now three cylinders are working. The right one isn't firing and when I try to rev the bike up it totally bogs and stalls....So anyone, where do I start from here to find the problem?
pull the remaining spark plug out, leave it connected, see if its sparking at all. if it isn't, look at your coils.
ok, I took the spark plug that is not firing out. I plugged it in and set it on the eigine block to ground it. I didn't see any spark. Now should I test the line from the coil to the spark plug? I heard that gets crud in it that you can clean with sandpaper.
test the line... if your not getting any power through it, check if you have power at the coil
if theres power at the coil then the wire is the problem... if not, the coil is probably at fault
crazypj said:
For a single cylinder not to fire its either stuck float valve (too much fuel) or blocked jet ( not enough fuel)
PJ
The float bowls seem fine. Spark plugs are all working. They are all new. How to I see if the float valve is messed up. It's strange cause this happened pretty quick. When I start the bike it takes a little more effort to turn the bike over. Usually it starts cold no problem. When I try to give the bike gas it stalls. Also one of the out takes is not hot (not firing).
Do I need to clean the carbs or something?
+1
you're remarkably harsh. take a valium or whatever it is you do in your parts.
regardless of the type of coil, no spark = no spark, right?
i mean, you haven't even entertained the idea that the lead might be fucked, or the super-magical-hard-to-understand coil has degraded with age. you're just calling me a retard. if there's something critical i've missed, perhaps enlighten rather than attack?
is this problem a spinoff of the original 1/4 mile problem? if so, check the gas tank vent, if the carbs are emptying out when the bike is actually running (not idle), then it will cause that problem. as far as the one cylinder not firing, it's a lost spark system, so each cylinder has 2 sparks, as pj said, if it were electrical, it would cause 2 not to run. could be the lead, but... less likely. sounds like the carbs
i'm not arguing, just for my own reference: how would a lost-spark system result in a plug not firing at all?
whenever i've had issues with motors not firing on all cylinders, i invariably look at spark first... if i was trying to sort out spark, and it didn't spark after a day's troubleshooting, i'd go batshit postal on the nearest non-valuable inanimate object if i were to find out it had anything to do with a carb.
Nice, I started a post that soon led to a fight. Nobody is a retard here. I fucking hope not cause you ride motorcycles, that would be bad for everyone on the road.
As far as what I have tracked down on my bike it must be a dirty/faulty carb. Now I need to learn to to clean that out without having to retune them.
Maybe the saddest thing. A day before this breakdown I just got a new back tire, chain and sprocket! CB's aren't supposed to be money pits ???
