Blue flames out of tail pipes?!
cgguy09
1971 CB350 K3
I know...I know I never thought I'd consider this awesome event a problem. 8)
This engine (and the rest of the bike) was literally just rebuilt & brought back to life at 8:24 PM CST. It runs great, good idle, good throttle response, (a little back fire, but I need to rejet the carbs due to new air pods). But once about every minute or two a blue flame shoots out of the right tail pipe.
when I rebuilt the engine I used a gasket set from Ebay, and I put a little (a little) liquid gasket on some known trouble spots. (would that be making the flame?) other than that I have no idea what would be causing the odd colored fire on the back end...
Thanks boys, as always appreciate the help.
AlphaDogChoppers said:
You already said it needs to be rejetted.
Can you say, "Well, duh!"
Ha Ha, alright, works for me. This bike was up & running 2 months ago with the same set up but without the flames. But, if thats the cause, should be an easy fix.
I'm just being a smartass. <G>
There are several things that can contribute to this, and I don't have time right now to go into a lot of details right this minute. Usually, decel popping and flames out the exhaust indicate a lean condition. Mixture is lean, so it burns poorly in the combustion chamber, therefore, fuel air mix goes into exhaust where it sometimes will ignite.
Look for leaking intake. Also, leaking exhaust at the exhaust port can cause popping.
Running pods, you DEFINITELY MUST rejet. Without rejetting, the engine will be dangerously lean. There is a recent thread on this forum from someone who burned holes in his pistons because he installed pods and didn't rejet.
Good to know! Honestly I've been putting it off, but after spending 2 months rebuilding this thing, I'm not taking any chances.
Appreciate the quick feedback!
A lean condition causes a misfire, the fuel mixture doesn't light up. The unburnt fuel/air mixture gets exhausted into the pipe. the next time around, the mixture in the cylinder lights and exhausts into the pipe, where the unburnt mixture is waiting. the hot exhaust ignites the fuel and pop, you have a back fire. But the actual name is after-fire. Technically, a backfire is through the intake system, out the carbs. An unwanted explosion in the exhaust is an after fire.
So previous poster is right. If you are getting after-fires, it is most likely an overly lean condition.
